Yesterday, 12:47
Hi there,
I am looking for a tool to visualize Siemens PXC4/5/7 controllers with LM communicating the data points via Bacnet/IP.
If I understand correctly in this case I would need to use the bacnet client library of LM. I tried looking into the capabilities of the bacnet client and I have found older forum posts stating that it's limited in the number of data points it can handle and also lacks discovery features.
Would there be a viable solution to read and write a few hundreds of data points with the bacnet client of LM? If not, could you recommend any other solutions with LM?
Thank you for your answer in anticipation!
