Yesterday, 23:09
Hello, one of the features of the application we are developing is to periodically send an email with a CSV report attached. We implemented this using a script, and it works very successfully.
However, when we tried to embed this functionality into the application's index.lp file, we were unable to send even a plain email, let alone one with an attachment. This is the same Logic Machine where the email works perfectly fine via scripts.
I am sharing the working script below. How can we properly integrate this into the application?
--Gmail (smtp) username
user = '***@gmail.com'
--Gmail (smtp) password
password = '***'
--From
from = '<' .. user .. '>'
alias_from = 'gonderenhesap@gmail.com'
--REceiver
to = '***@***.com'
alias_to = '***@***.com'
--Email subject
subjectpart1 = 'Alarmlar'
subjectpart2 = 'Logic Machine Tarafindan Gonderildi'
--Message
epilogue = 'Mesajin sonu'
-- Get all alerts from DB
alerts_table = db:getall('SELECT * FROM alerts')
-- csv buffer
buffer = {}
-- format csv row
csv = string.format('%q,%q,%q', "ID", "ALERT", "ADDED TO LIST")
-- add to buffer
table.insert(buffer, csv)
-- add empty line to buffer
table.insert(buffer, "")
-- Loop through alerts_table
for _, alerts in ipairs(alerts_table) do
-- format csv row
csv = string.format('%q,%q,%q', alerts.id, alerts.alert, os.date("%x %X", alerts.alerttime))
-- add to buffer
--Create table to include mail settings
local settings = {
from = from,
rcpt = to,
user = user,
password = password,
server = 'smtp.gmail.com',
port = 465,
secure = 'sslv23',
--Create attachment inside FTP server
src = 'AlertExport_'.. os.date('%Y-%m-%d %H#%M#%S') .. '.csv'
dst = '/home/ftp/' .. src
log(io.writefile(dst, buffer))
log("file created")
log(dst)
--Create subject
subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2
--Load required modules to send email with attachment
local smtp = require("socket.smtp")
local mime = require("mime")
local ltn12 = require("ltn12")
--Create e-mail header
settings.source = smtp.message{
headers = {
from = '' .. alias_from .. ' ' .. from .. '',
to = '' .. alias_to .. ' ' .. to .. '',
subject = subject
--Load attachment inside body
body = {
preamble = "",
[1] = {
headers = {
["content-type"] = 'text/plain',
["content-disposition"] = 'attachment; filename="'..src..'"',
["content-description"] = '.. src ..',
["content-transfer-encoding"] = "BASE64",
body = ltn12.source.chain(
ltn12.source.file(io.open(dst, "rb")),
ltn12.filter.chain(
mime.encode("base64"),
mime.wrap()
epilogue = epilogue
--Send the email
r, e = smtp.send(settings)
--Create alert when sending gives an error with error message
if (e) then
log (e)
log (r)
-- FTP Uploader --------------------------------------------------------------------------
-- local ftp = require("socket.ftp")
-- local ltn12 = require("ltn12")
-- f, e = ftp.put{
-- host = "ftp.test.tv.tr",
-- user = "fgtest@test.tv.tr",
-- password = «ftpsifresi",
-- command = "appe",
-- argument = src,
-- source = ltn12.source.file(io.open(dst, "r"))
--Delete created file from ftp folder inside HL
os.remove(dst)
