Threads: 148
Is possible use scheduler frame in new Visu?
I try but not have possibility to link to scheduler.
Tank's
Threads: 30
Just use
/scada-vis/schedulers
Threads: 4
08.04.2026, 23:23
(This post was last modified: 08.04.2026, 23:24 by Juande.)
I work with several Logic Machines on the same cloud account (for example, one at home and another at the office).
When accessing the planners through the cloud, the "Networks" button appears (top right corner), which allows switching between devices. This shortcut switches between Logic Machines, but only in terms of scheduling; the plan remains the Logic Machine selected in the plan menu.
How can I hide this shortcut so that the Logic Machine is selected from the main menu?
This same problem occurs in trend logs; how can I hide it there as well?
Thank you very much!
Threads: 48
Network selection button is now hidden when Trends/Schedulers are included in Visu via frame element.
