Threads: 12
Is it possible to insert a link containing your username and password into a widget frame within the Visu application?
Currently, it only works in the browser, while the application only displays "Unauthorized."
Threads: 31
What do you want to embed in the frame?
Threads: 12
A cloud site with additional data about the building
Threads: 31
What is the url format with auth?
You must enable Allow external access via iframe: Utilities - vis.config
Threads: 12
I set this parameter, and it works with the browser.
The authentication system consists of simply typing your username and password. The browser stores it and automatically logs you into the site.
Threads: 31
Do you use http locally and https to the cloud?
Can you share the link and credentials via PM?
