Question about mobile visualization best implementation approach
Hi all,
I’m planning a mobile-friendly visualization for LogicMachine and I’d like to ask whether this is doable and what the best implementation approach would be.
The idea is:
At floor level, I would like to have a compact list of rooms using single-line, full-width tiles:
When selecting a room, I would like to open a full-screen room detail view:
Can Mosaic handle this kind of room list → room detail navigation cleanly, or would the new Visu be more suitable for this type of mobile UI?
Any suggestions, examples, or advice on the best way to implement this would be appreciated.
Thanks!
George
It's strongly recommended to use Visu, not Mosaic for new projects. If you want to create something very similar to these screenshots then you will have to make custom widgets. Otherwise you can simply use built-in widgets, adjust the global color scheme and maybe add some custom CSS.
I like the idea of having the "go to plan" in the bottom, like the screenshots OP sent. Is it possible to insert a widget, that always is placed in the lower row (left, middle, right-setting) ? Smile
The only solution for now is a custom implementation using JS/CSS.
