Multi IP Tunneling
Dear all,
I have a LM that must communicate with no.19 KNX/IP Tunneling devices.
Is it possible set a proper communication with those different IP addresses? How can I set it?
LM can connect only to one IP tunnel. You should use IP routers instead.
(Yesterday, 15:02)admin Wrote: LM can connect only to one IP tunnel. You should use IP routers instead.
Thank you Admin!
