Threads: 7
I've read references in old threats to this document: Mosaic_widgets_eng.pdf
The links to the document is no more valid.
Can some of you provide a correct link or can send me a copy ?
Thanks in advance for your help
Antonio
Threads: 35
What are you trying to do with it? Custom code based widgets will work only locally. It is better to use custom widget Editor.
Or best is to use new Visu.
Threads: 7
I'm trying to create widgets for my sauna and my ventilation machine, with embedded logic, so I would like to be able to create a widget and edit its html and code. I cannot use the new visu, I'm using SE wiser for knx, and I've only available the old visu and the touch interface (which I assume is mosaic, correct?)
Threads: 35
Yes it is based on Mosaic but SE did a lot of modifications to it and I can't guarantee that our doc is still valid for this version. I don't even know if they still kept the option to import widgets.
Here is the file but you wont get any support from us on this.
https://www.transfernow.net/dl/20260528KhZ67BCb
