button confirm
Hello, is it possible to validate an action like this with a button?
<script>
if (confirm("Do you want to continue?")) {
document.write("yes")
} else {
document.write("no")
</script>
Thank you
What task do you have exactly?
(01.06.2026, 13:07)admin Wrote: What task do you have exactly?
ask for confirmation of the operation I am going to do if I answer yes
Ok, but what action do you want to perform? Change group address, show a different plan or open some link? Is it something that can already be done using an existing widget (which?) or do you need something fully custom?
(02.06.2026, 07:45)admin Wrote: Ok, but what action do you want to perform? Change group address, show a different plan or open some link? Is it something that can already be done using an existing widget (which?) or do you need something fully custom?
Simply, from a virtual button with a script, I'd like an alert that authorizes its execution.
For example, if you leave the house, it responds, "Are you sure?" Yes, I execute the command; no, I cancel the command.
A out of the box option(no the same) is PIN protection.
This example adds a confirmation to the switch widget.
Change widgetId value to your switch widget ID. ID is shown in the window title when editing a widget.
const widgetId = 26
Visu.on('widget-ready', widgetId, ({ widget }) => {
  const component = widget.component
  const handler = component.compactModeClick
  component.compactModeClick = () => {
    Visu.emitter.emit('confirm-dialog-show', {
      text: 'Are you sure?',
      callback: handler
Fantastic
