Threads: 163
Good morning, I need to know if it's possible to monitor multiple LMs from a single point. I tried opening windows pointing to the other LMs on a "MASTER" logic machine. Is this the correct way to do it? How can I centralize the alarms on a single LM?
Can you suggest a better or optimal way?
Threads: 31
Are the LMs local or in different locations?
Threads: 31
In this case use cloud and in cloud they can jump between projects. To have centralised alarms one of the LMs must collect all of them. If they are in different locations you can use this to gather data.
https://kb.logicmachine.net/integration/mqtt-cloud/
