26.06.2026, 07:29
We are experiencing an intermittent remote access issue with one of our LogicMachine 5 Lite devices and would like to know whether this behaviour is already known.
Hardware
The LogicMachine is accessed remotely through a private ZeroTier network.
The behaviour is always the same:
Tests already performed
ZeroTier
When connected to the local LAN:
System load
Average load:
0.09 / 0.09 / 0.09
The LogicMachine is almost idle, so this does not appear to be a resource issue.
Comparison with another installation
We have another installation with very similar characteristics:
Working LogicMachine
Additional observation
We also noticed one difference in the HTTP server configuration:
The LogicMachine is connected to the Internet through a UniFi UDM Pro and Starlink.
We have already reviewed the gateway configuration (firewall, IDS/IPS, VPN, routing, CyberSecure, etc.) and did not find anything unusual.
Question
Is this a known issue with firmware 20251204 or Linux kernel 5.10.247?
Have you received any similar reports regarding intermittent HTTP/HTTPS access over ZeroTier?
Before downgrading the firmware to 20250813, we would like to know whether this behaviour is already known or if you recommend any additional diagnostic procedure.
If necessary, I can provide system logs, perform any additional tests you recommend, or provide any further information required.
Thank you very much.
Hardware
- LogicMachine 5 Lite (i.MX6)
- Firmware: 20251204
- Linux kernel: 5.10.247
- HTTP/HTTPS access via the ZeroTier IP works normally for some time.
- After an unpredictable period, the web interface stops responding.
- The browser eventually reports that the device is not responding or the connection times out.
- A few minutes later, without any intervention, the web interface starts working again.
ZeroTier
- Service enabled
- Status: OK
- Port: 9993
- Private network
- DIRECT connection (not relayed)
- Ping through ZeroTier usually works, although larger ICMP packets show intermittent packet loss.
- TCP port 80 is reachable.
- TCP port 443 is reachable.
- ETS6 continues communicating through the LogicMachine KNX/IP interface without interruption, even while the web interface is no longer responding.
- ZeroTier remains connected.
- KNX/IP communication continues working correctly.
- The issue appears to affect only HTTP/HTTPS access through ZeroTier.
- The web interface is always accessible.
- No communication problems have been observed.
System load
Average load:
0.09 / 0.09 / 0.09
- Same LogicMachine 5 Lite hardware
- Same ZeroTier network
- Starlink Internet connection
- Remote access through ZeroTier
- Firmware: 20250813
- Linux kernel: 5.10.240
- Uptime: more than 57 days
- Stable HTTP/HTTPS access over ZeroTier
- Intermittent HTTP/HTTPS access over ZeroTier
- HTTP and HTTPS enabled.
- HTTPS only, with automatic HTTP → HTTPS redirection.
Question
