Threads: 87
for some tests I connected back to LM USB Zigbee stick E18-2G4U04B to LM USB port. Zigbee config I switched to USB. But not working, at used ports USB stick not seen. Do I need to do some usb port setting/reinitialization? Previously modem was connected to USB port. Will it work with latest FW of LM? Actively stick was used ~ 4 years ago. Can I also use USB HUB?
Init script:
os.execute('echo 1 > /sys/bus/platform/devices/ci_hdrc.0/force_full_speed')
os.execute('echo 1 > /sys/bus/platform/devices/ci_hdrc.1/force_full_speed')
os.execute('usbreset /dev/bus/usb/001/001')
Alex
Post what you have in System config > Status > System log when the dongle is connected to LM.
Threads: 87
Hi, restarted LM. Log:
Jul 3 12:13:23 Home daemon.info avahi-daemon[1236]: Service "Web Server on Home" (/etc/avahi/services/http.service) successfully established.
Jul 3 12:13:23 Home daemon.info avahi-daemon[1236]: Service "Home" (/etc/avahi/services/lm.service) successfully established.
Jul 3 12:13:22 Home daemon.info avahi-daemon[1236]: Server startup complete. Host name is Home.local. Local service cookie is 1131558326.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Registering HINFO record with values 'ARMV7L'/'LINUX'.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Registering new address record for 192.168.45.156 on eth0.IPv4.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Network interface enumeration completed.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: New relevant interface eth0.IPv4 for mDNS.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.45.156.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Loading service file /etc/avahi/services/lm.service.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Loading service file /etc/avahi/services/http.service.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: avahi-daemon 0.8 starting up.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Successfully dropped root privileges.
Jul 3 12:13:21 Home daemon.info avahi-daemon[1236]: Found user 'nobody' (UID 65534) and group 'nogroup' (GID 65534).
Jul 3 12:13:15 Home kern.info kernel: [ 10.995488] IPv6: ADDRCONF(NETDEV_CHANGE): can0: link becomes ready
Jul 3 12:13:10 Home user.info sysinit: /lib/genohm-scada/storage/db/current.db: OK
Jul 3 12:13:09 Home kern.info kernel: [ 5.159419] fec 2188000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
Jul 3 12:13:08 Home kern.info kernel: [ 3.276218] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: nodelalloc
Jul 3 12:13:07 Home user.info sysinit: /dev/mmcblk0p3: clean, 3289/38400 files, 35144/153600 blocks
Jul 3 12:13:07 Home user.info sysinit: e2fsck 1.47.2 (1-Jan-2025)
Jul 3 12:13:07 Home kern.info kernel: [ 3.123267] SMSC LAN8710/LAN8720 2188000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
Jul 3 12:13:06 Home kern.info kernel: [ 1.983184] SMSC LAN8710/LAN8720 2188000.ethernet-1:00: attached PHY driver [SMSC LAN8710/LAN8720] (mii_bus:phy_addr=2188000.ethernet-1:00, irq=POLL)
Jul 3 12:13:06 Home kern.info kernel: [ 1.652440] cdc_acm 1-1.1:1.0: ttyACM0: USB ACM device
Jul 3 12:13:06 Home kern.info kernel: [ 1.649664] usb 1-1.1: SerialNumber: __0X00124B0014DBCDAB
Jul 3 12:13:06 Home kern.info kernel: [ 1.649653] usb 1-1.1: Manufacturer: Texas Instruments
Jul 3 12:13:06 Home kern.info kernel: [ 1.649640] usb 1-1.1: Product: TI CC2531 USB CDC
Jul 3 12:13:06 Home kern.info kernel: [ 1.649627] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 3 12:13:06 Home kern.info kernel: [ 1.649583] usb 1-1.1: New USB device found, idVendor=0451, idProduct=16a8, bcdDevice= 0.09
Jul 3 12:13:06 Home kern.info kernel: [ 1.535165] usb 1-1.1: new full-speed USB device number 3 using ci_hdrc
Jul 3 12:13:06 Home kern.info kernel: [ 1.458112] EXT4-fs (mmcblk0p2): re-mounted. Opts: nodelalloc
Jul 3 12:13:06 Home kern.info kernel: [ 1.248553] hub 1-1:1.0: 7 ports detected
Jul 3 12:13:06 Home kern.info kernel: [ 1.248329] hub 1-1:1.0: USB hub found
Jul 3 12:13:06 Home kern.info kernel: [ 1.247579] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Jul 3 12:13:06 Home kern.info kernel: [ 1.247550] usb 1-1: New USB device found, idVendor=0424, idProduct=2507, bcdDevice= 0.00
Jul 3 12:13:06 Home kern.info kernel: [ 1.091261] usb 1-1: new high-speed USB device number 2 using ci_hdrc
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895195] TERM=linux
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895190] HOME=/
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895184] with environment:
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895181] /etc/preinit
Jul 3 12:13:06 Home kern.debug kernel: [ 0.895175] with arguments:
Jul 3 12:13:06 Home kern.info kernel: [ 0.895164] Run /etc/preinit as init process
Jul 3 12:13:06 Home kern.info kernel: [ 0.891199] Freeing unused kernel memory: 1024K
Jul 3 12:13:06 Home kern.info kernel: [ 0.889900] VFS: Mounted root (ext3 filesystem) on device 179:2.
Jul 3 12:13:06 Home kern.warn kernel: [ 0.889827] ext3 filesystem being mounted at /root supports timestamps until 2038-01-19 (0x7fffffff)
Jul 3 12:13:06 Home kern.info kernel: [ 0.889763] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
Jul 3 12:13:06 Home kern.info kernel: [ 0.862804] mmcblk0: p1 p2 p3
Jul 3 12:13:06 Home kern.info kernel: [ 0.861520] mmcblk0: mmc0:1234 SA32G 28.8 GiB
Jul 3 12:13:06 Home kern.info kernel: [ 0.860443] mmc0: new high speed SDHC card at address 1234
Jul 3 12:13:06 Home kern.warn kernel: [ 0.858348] mmc0: host does not support reading read-only switch, assuming write-enable
Jul 3 12:13:06 Home kern.info kernel: [ 0.858064] Waiting for root device /dev/mmcblk0p2...
Alex
Enable debug logging in the ZigBee app configuration and post what you have in the ZigBee app logs.
Threads: 87
Finally USB Zigbee started after 3rd reboot, may be USB Hub not seen previously
Alex
