Frame Trend logs from Neighbour
Hi!  Smile
Is it possible to use the Frame widget to view a Trend logs URL from a neighbour with the new Visu?
I've tried but runs into a problem where i have to login to the frame.
This can work but it is not related to Visu only how the modern browsers works. First you must use HTTPS on both controllers and in the frame url. Second you must create valid SSL certificate for both LMs(use SSL cert app) Last point is to set Remember password in User settings. It will ask you for credentials once till the remember parameter will expire.
(4 hours ago)Daniel Wrote: This can work but it is not related to Visu only how the modern browsers works. First you must use HTTPS on both controllers and in the frame url. Second you must create valid SSL certificate for both LMs(use SSL cert app)  Last point is to set Remember password in User settings. It will ask you for credentials once till the remember parameter will expire.
Thank you!  Smile
