1-Byte Object – Prevent Numeric Keypad from Opening
Dear Support Team,
I am experiencing an issue with a 1-byte object.
The customer can adjust the 1-byte setpoint using the + and − buttons, which works as expected. However, if the customer accidentally taps the center of the control, the numeric keypad opens.
Is it possible to prevent the keypad from opening by using a user script or another scripting method?
I am using a LogicMachine 5.
Thank you in advance for your prompt response.
Kind regards,
See this: https://forum.logicmachine.net/showthrea...5#pid37665
