58 minutes ago
I need to set up a centralized supervision system for 6 LogicMachines (LMs) on the same network. I was thinking of using MQTT. Since I need to acquire 200 objects from each LM—meaning I would eventually need to create around 1,200 alarm scripts on the master unit—I wanted to know which LogicMachine model you would recommend using as the MQTT master. Has anyone done something similar?
Thanks a lot.
Thanks a lot.
