Multiple LM in same network
Hello Dears,
What is the best configuration to sepaerate multiple LM from each others.
while each one represent differnt appartment and placed in a different KNX Line.
Best Regards,
Disable IP routing on all devices so they don't exchange values automatically. For improved security networks should be split into different VLANs. You need a managed switch for that.
(10 hours ago)admin Wrote: Disable IP routing on all devices so they don't exchange values automatically. For improved security networks should be split into different VLANs. You need a managed switch for that.
Thank you admin
No need to change Multicast IP if IP routing disapled?
Best Regards,
No, you can keep the default address.
