Threads: 1
Hi, does the Aqara LED Bulb T2 E27 work with the LogicMachine Zigbee gateway in Zigbee mode? I could not find it in the supported device list. Does it support on and off, dimming, colour temperature and RGB? If not, can support be added? Thanks.
Threads: 35
If it is not on the list then you know the same as we do. If they fallowed zigbee standard then the basic control should work.
Threads: 35
Pair it and test it. Send device information form the app.
