Logic Machine Communication - HTTP
Star
Hello, I would like to know, how can I take information from an HTTP page from the logic machine? Big Grin
http://w3.impa.br/~diego/software/luasoc...ml#request
If you just need a simple datafield you can also use:
require('socket.http')
socket.http.TIMEOUT = 5
-- Get data from website
local data = socket.http.request('http://openrb.com')
-- Check if data is received
if not data then
    log('No data found')
    return
-- Find your data
for i in string.gmatch(data, '<body>.-</body>') do
    if i ~= nil then
        searched_data = i:match([[<h2>(.-)</h2>]])
        if i ~= nil then
            log(searched_data)
Hi, Erwin van der Zwar:
Thanks for your help. Yes, it is a simple data capture, use your code but it is not registering anything to me.
The data is now fetched between <h2> </h2> fields but i don't know the fields in your html mark-up so you have to check that and change it to those..
log(data) to see your complete reply from your url source.. or right click your source in the browser and select 'view source code' to see the structure of the site you read..
Check is gateway and DNS are set in network config.
I adjusted the sample to a (tested) version to fetch all the main topics from this forum
local data = socket.http.request('http://forum.logicmachine.net')
if not data then
  return
-- Find your data
  if i ~= nil then
     for j in string.gmatch(i, '<a href="forumdisplay.-</a>') do
        if j ~= nil then
           searched_data = j:match([[">(.-)</a>]])
           if searched_data ~= nil then
              log(searched_data)
It works, thanks for your help. Big Grin
