KNX/TP alerts/errors
I have strange errors and alert in LM4 latest firmware:
Errors:
KNX/TP: Transmitter Error (send 0 receive 1)
KNX/TP: Temperature Warning
Alerts:
KNX/TP: Connected
KNX/TP: Disconnected
Source - system. Messages may repeat ~0-10 times a day. All works properly without any issues.
What does this mean?
I can confirm this - seeing this also on my LM5-PMU.
Everything working fine.
Best regards,
Bart
I second that confirmation. Have a LM4 doing this also. LM4 is connected on the main line with 4 other MDT bus couplers. Have replaced the bus couplers already.
Thanks,
Roger
Does anyone have a solution for this, I have 2x LM4 that do this. What I have discovered is that this happens when I program with ETS more than 2 devices on the bus with the LM.
Thanks,
Roger
Check out this topic:
https://forum.logicmachine.net/showthread.php?tid=1261
It's the same issue.
