Analogue I/O module
Do you have an analogue input / output module? I can't see it. The only product I've found is "20 I/O extension module" here http://openrb.com/io-extension-module-fo...2-reactor/
But it's input only.
LM5Lp, firmware: 2018.08.22, FlashSYS v2, ARMv7 Processor rev 5 (v7l), kernel 4.4.151
You can use Reactor Dimmer with 8x analog inputs, 3x 0-10V outputs and 1x 4-20mA output:
http://openrb.com/logicmachine5-reactor-dimmer/
I need at least 6x analog input + 6x analog output
I've found this
http://openrb.com/swiss-knife-32-io/
It was well hidden. Is this product still available?
(14.06.2017, 10:08)Thomas Wrote: I need at least 6x analog input + 6x analog output
I've found this
Hi, Thomas.
this device was not realesed. and it had no analog outputs, only digital outputs
