Threads: 100
I have a LM4 with two dali devices connected to the internal Dali port.
Dali power supply: WAGO 787-1007
Dali devices: Osram halotronic hti dali 105
But when i use the scan devices button, no devices are found? Whats going wrong? Do i need some more configuration?
Wago 787-1007 is not DALI power supply but a power supply for Wago DALI gateway. It does supply correct voltage but it does not have DALI-specific circuitry, that's why there is no transmission happening on DALI line.
Threads: 0
I have LM4, Tridonic Dali PS2 for power supply and about 10 dali devices. Dali devices are connected in star.
I connected it to LM4 internal DALI gateway. When I scan for dali device, no device found. Somehow once I succeeded and all devices were found, but after I added another one, and tried to scan for new devices no result. I tried to do full scan and now I dont see any devices. What could be wrong?
Also dimming, when device were found, was not working, example, if I set value to 10%, lights were blinking or not working at all.
Could it be problem with Dali power supply?
