17.06.2017, 06:29
begin working with DALI - did not find on forum how to receive feedback from DALI devices.
I need status of lamp - is it ON or OFF, if ON - receive to LM dimming level. With other gateways also possible receive status of DALI ballast - is it working or not, also error if lamp is broken. What we can do with LM DALI bus and RS485/DALI interface?? Found DALI commands, but may be somebody can provide examples or a little more details??
Also recommend to developers add 2 possibilities to DALI interface - broadcast FLASH command - all lamps will flash with interval 0.5 sec as example..(Possible make script but I still learning LUA). Very need for first startup - we will see which lamps not receive DALI commands or not added to interface (but for this not sure - may be in broadcast mode all DALI devices will flash, even thous which still not added in device list in LM??). Second possibility - when we found devices and begin to set up them - Flash possibility for selected device fill help us to see we work with device we need. Manually switch on/off not so comfortable, I have more 250 lams in my project, installation of them made other persons..
