Which LM model do I have here?
Gotta do a remote firmware update on an LM5, issue is that I dont know which model or hardware it is.
Can you help?
Attached photos from system status.
Some kind of an older LM5 power. What genohm-scada packages do you have in System > Packages?
Or look on the side label.
(20.03.2023, 11:26)admin Wrote: Some kind of an older LM5 power. What genohm-scada packages do you have in System > Packages?
Thanks for the fast reply.
See attached photos.
Need to update firmware to make the LM cloud work again
(20.03.2023, 11:34)Daniel Wrote: Or look on the side label.
I dont have the unit available atm
You need LM5 Lite + Ext (4 or 6 DIN units).
(20.03.2023, 11:37)admin Wrote: You need LM5 Lite + Ext (4 or 6 DIN units).
The old or new cpu model? Probably the oldest mx28?
New CPU model
