LogicMachine5 Reactor IO v2
LogicMachine5 Reactor IO v2 is all-in-one cross-standard controller uniting in one device gateway functionality, cloud service integration, complex network logic engine, easy-to create visualization platform, IP Router, I/Os and much more.
v2 differs from initial v1 with possibility to use inputs for pulse metering, plus V2 has 2 analog outputs and 1-wire on board
Hightlights:
  • 18 I/O ports
  • LM5 Reactor IO v2 has built-in KNX TP1, EnOcean bi-directional interface (optional), two serial interfaces
    Power-over-Ethernet powering
  • Application development and application store
  • Cloud ready device with Microsoft Azure, Amazon Web Services and other services supported
  • Gateway and uniform way of control of KNX, ModBus RTU/TCP, BACnet IP, EnOcean (optional), DMX, M-Bus, GSM and more
  • Unlimited scenario and logic engine
  • Unlimited visualization platform for PC and for touch devices
  • Size: 6 DIN units
  • Remote KNX bus control and KNX device reprogramming
  • Object logging with trends support and data exporting to external servers
  • Optional 3x more powerful CPU than all previous LogicMachine versions
[Image: LM5-RIOE2-300x263.png]
See here i.MX28 (CPU of LM2, LM3, LM4) and i.MX6 (optional 3x speed CPU for LM5 series devices) comparison tests: http://openrb.com/imx28-vs-imx6-cpu-test...icmachine/
Here is more information on LM5 Reactor IO v2: http://openrb.com/logicmachine5-reactor-io-v2/
LM comparison table: http://openrb.com/wp-content/uploads/201...17_web.pdf
Hy,
I was update firmware "LogicMachine5 Power / LogicMachine5 Reactor IO Power" and now can't see reactor tab with inputs and outputs.
