Threads: 22
Is it possible to connect a RS485/USB converter to use a Z-Wave stick/dongle on the LM5?
Most problably it won't work because full-duplex communication is needed. You can try using USB hub instead if you don't have enough USB ports.
Threads: 22
24.07.2017, 07:13
(This post was last modified: 24.07.2017, 07:13 by Krstfr2k.)
I have the LM5-Lite without the USB port...
