HomeLynk shutter function
Need urgent assistance :-)
Is there any way in Schneiders HomeLynk where you can make a pushbutton in the visualization to send to one KNX group address on press and send on another on release? Need to sort out a function for shutters where you have to keep the button pressed for it to move and stop as soon as you release the button. Thought it would be a common thing to do. It only sends on release at the moment.
Anyone got any examples and soultions to share?
Cheers
MZW
You can set start/stop or stop/start mode in Vis. parameters, which will send true/false or false/true on press/release to the selected group address. If you need to send values to two different groups, you can use a simple script attached to the triggering group.
