Threads: 13
Just updated the mosaic app on Firmware 20160927
Now mosaic breaks and also the mosaic editor.
All i get is:
Error in /www/apps/data/mosaic20/index.lp at line 16: unexpected symbol near '='
Threads: 13
After upgrade to 20170620 mosaic works again
Threads: 0
Hi ,
is there a remote possibility to add "Mosaic" to the Schneider's homelynk ?
Thank you
Threads: 8
No that is not possible, we have Touch and Wiser for KNX remote as solution.
Threads: 0
After upgrade to Mosaic 2.0 20180802 I've got a new icon in the apps list (CAN) and the following message started to appear in the error log every 3 min:
Error log 07.10.2018 21:56:42
Line 3: module 'canx' not found:
no field package.preload['canx']
no file './canx.lua'
no file '/usr/lib/lua/canx.lua'
no file '/usr/share/lua/canx.lua'
no file '/usr/lib/lua/canx.so'
What to do with it?
LM5-DR
Please reinstall mosaic from the app store, this issue is fixed.
Threads: 13
Not really fixed still have the issue but less then before, probably because I have been using the canx app that was temporarily there...
cannot open /home/apps/store/daemon/canx/daemon.lua: No such file or directory
Threads: 13
This keeps coming back even after reboot
Threads: 31
Then you can try:
- make a backup,
- then factory reset
- install apps you were using
- restore your backup.
Threads: 13
Sorry Daniel, not an option to do a fresh install. I have custom packages from knxlogic.be which need to installed manually. I wil have to wait for the final firmware before I do this. Any eta ?
