Threads: 39
Hello, what to do when you have an error in the sreenshot attached.
We init the trend with bad datatype... or sometimes you get a false value and you want to remove only this value ?
SE ECO EXPERT
Threads: 3
Maybe you can update the trend directly in the DB, but not sure how to do this or even if it's possible.
I let admin answer, or maybe Erwin.
Threads: 7
Trends are not stored in the normal DB but in RRD files (round-robin database)
Deleting data from this trend data files is not easy to do as there are multiple calculations done on the data (average data points).
As i see on the trend there is almost no data in it yet so i would advice to delete current trend and recreate it on the correct dpt.
Threads: 39
(24.08.2017, 20:56)Erwin van der Zwart Wrote: Hi,
yes I did it.
I found also that in backup we can modify it !
I was speaking about this problem, because in other project, sometimes you have bad modbus communication, then wrong value, then Trend with terrible Axis resolution !
SE ECO EXPERT
