Mosaic 2.0 what's new
Hello!
You are often doing Mosaic 2.0 update. Sometimes not possible to recognize, what was changed.
Where to see changes/what's new information of each update?
Reminder!
(28.12.2017, 19:20)GenaV Wrote: Reminder!
In did we should post the updates :Smile
We corrected Air Conditioner widget to use correct DPT like for temperature.
There is new Video widget where you can play some web video. It can also be used for IP camera. You can see there 2 URLs one for local and second for remote which will be used in Mosaic Cloud.
We are working on new solution for IP cameras and this will be part of it.
Hi Daniel,
Great to see some updates for mosaic :-)
As for the video widget, what type of url's need to be configured ?
-jpg
-mpeg
-mxpeg (mobotix)
Nicky
(30.12.2017, 22:42)npinguin Wrote: Hi Daniel,
-jpg
-mpeg
-mxpeg (mobotix)
Nicky
We are still limited to what the browser can display. Tested jpeg, mjpeg, mp4. You can try mxpeg and let us know.
Thanks Daniel
I got the following working
Mobotix t25 cam
-http://MYIP/cgi-bin/faststream.jpg?stream=full&fps=0&data=v.mjpg
Axis m1065 Cam
- http://MYIP/axis-cgi/mjpg/video.cgi
But I got a problem with the security:
-need to provide the credentials of each Cam to get it working.
- Unfortunately I cannot provide the username password in the url (http://username:password@url), because then it cannot connect
If I would build a solution, I would recommend
- a dedicated solution integrated in the LM based on FFmpeg
- ability to configure Cam’s and views
- api’s to control the different cam’s and streams/views
- streaming and snapshot mode
have a look at netcamviewer monitor
(31.12.2017, 14:45)npinguin Wrote: Thanks Daniel
Mobotix t25 cam
Axis m1065 Cam
Similar solution we are working on now.
Excellent, mind reading  Smile
In latest version we corrected security widget and now when code is typed the window opens in popup. Due to this buttons are much bigger and easier to press.
Great Daniel, indeed much easier to use
