Threads: 6
No for HL you need a different image, i will PM you my mailadress so we can exchange it.
Threads: 7
Hi Edgars,
I was using your bluetooth script (using function ble.scan(callback)) for presence-detection - it worked fine.
After upgrading to RC1 it stopped working: I did install the correct pkg again - no errors there and BLE-tab showing up in the GUI. The script runs fine with no errors but no bluetooth devices are found - no errors are showing up either. Tried rebooting and unplugging/plugging bluetooth stick (BL from Lairdtech).
Any ideas?
Thanks Bart
Threads: 1
after updateting spaceLYnk to firmware version 2.0.0.
I don't have access to the bacnet settigns dialog any more.
At firmware version 1.2.1 I had access to the bacnet settings dialog.
Best regards
forsterm
Threads: 6
Try clearing browser cache.
Threads: 161
05.05.2017, 13:25
How about new firmware for Load Balancer? Maybe some good news for a finish of the week?
Threads: 40
RC2 is planned for next week, we'll prepare FW for LB as well.
Threads: 161
Great Did you added something new then above list of changes(RC1)?
Threads: 40
Just a couple of minor bug fixes, any new features will go into next major release.
Threads: 1
(05.05.2017, 10:29)Erwin van der Zwart Wrote: Hi,
clearing the browser cache solved the problem.
Thank you very much
Best regards
forsterm
Threads: 40
@bmodeco
Have you tried using the universal profile?
http://openrb.com/bluetooth-presence-detection-and-rssi
Can you post your presence script?
Threads: 89
(04.05.2017, 13:41)Erwin van der Zwart Wrote: Hi,
I have the same problem with a HL 1.3.1
Upgrade isn't possible.
New object is removed after restart.
Logs are removed from 12-2016 after restart.
Threads: 7
(08.05.2017, 08:53)admin Wrote: @bmodeco
Hi admin,
I am using the script on thread : http://forum.logicmachine.net/showthread...t=presence
It worked fine before RC1. Tried rebooting, unplugging and so on - no difference.
Thanks Bart
Code: require('ble')
-- enable ble
ble.up()
list = {}
-- mac -> group address mapping
known = {
['88:0F:10:10:F2:8A'] = '1/1/1',
['88:0F:10:4A:2C:36'] = '1/1/2',
ctime = os.time()
function callback(addr)
local now, delta
now = os.time()
delta = now - ctime
if addr then
if not list[ addr ] then
log('BLE found ' .. addr)
if known[ addr ] then
grp.write(known[ addr ], true, dt.bool)
list[ addr ] = now
-- check for missing devices each 5 seconds
if delta < 0 or delta > 5 then
for addr, time in pairs(list) do
delta = now - time
if delta < 0 or delta > 60 then
log('BLE missing ' .. addr)
list[ addr ] = nil
grp.write(known[ addr ], false, dt.bool)
ctime = now
ble.scan(callback)
Threads: 5
11.05.2017, 12:20
(This post was last modified: 11.05.2017, 12:22 by Jørn.
Edit Reason: additions
Unable to sort/filter any of the scenes in the scene tab. Could you add this in the next release? A real pain when trying to organize alot of them
edit: The same really goes for trends/schedulers etc as well
Have also noticed that in the other tabs, when filtering by category/tags, it only last for a couple of seconds, then all tags are showed again, haven't tried with another browser, but should work in Chrome i guess`?
Best regards, Jørn.
Threads: 40
Scene filter is planned for the next version. Trends/schedulers are sorted by custom user-defined order.
Can you explain the issues with tags that you're having in more detail?
Threads: 5
(11.05.2017, 13:52)admin Wrote: Scene filter is planned for the next version. Trends/schedulers are sorted by custom user-defined order.
When trying to filter scripts by category, it works for about a second or two, and then shows all of them again.
Best regards, Jørn.
Threads: 18
(11.05.2017, 14:39)joskilb Wrote: (11.05.2017, 13:52)admin Wrote: Scene filter is planned for the next version. Trends/schedulers are sorted by custom user-defined order.
I am seeing the exact same thing.
Mr.D
Threads: 40
Thanks, will have a look at this issue
Threads: 102
I've got a message "Cannot upgrade, firmware file is invalid"
Actual firmware 2017/04/07
Threads: 40
Are you sure you are selecting the correct firmware for your platform?
If is still does not work, run this script once and try installing again:
https://gist.github.com/jsopenrb/4ba040d...dbc6b74447
Threads: 102
18.05.2017, 12:04
(This post was last modified: 18.05.2017, 12:10 by Thomas.)
(18.05.2017, 11:27)admin Wrote: Are you sure you are selecting the correct firmware for your platform?
I use this firmware. Is it correct?
LM5 lite: https://dl.openrb.com/lm-17/lm5m3-20170424.img
I run your script once. Then I tried to upgrade my firmware. But the situation didn't change. Still the same message. Cannot upgrade firmware. Firmware image is invalid.
I'm sory, my mistake.
The correct file is LM5 lite: https://dl.openrb.com/lm-17-imx6/lm5m3-20170424.img
The file has the same name but is placed in a different directory.
