Threads: 37
I was thinking about an idea
Is it possible to enable the IP port 3671 with an icon on the visualisation.
For example, we port forward (without VPN) the 3671 port trhough Internet, but the customer can enable it/ disable it only when we needed maintenance !
Should be cool and "safe" (because it don't stay too much time enable, maybe watchdog...)
SE ECO EXPERT
Threads: 6
09.05.2017, 13:57
(This post was last modified: 09.05.2017, 14:01 by Erwin van der Zwart.)
Why don't you use a IP based forwarding instead of a 0.0.0.0 ?
This way only connections from that location are accepted.
Safest way and you can keep the port open if needed.
Threads: 37
(09.05.2017, 13:57)Erwin van der Zwart Wrote: Hi,
Yes you'r wright, however, every internet box doesn't allow this.
In my exemple, the suctomer has the feeleing to control when I can access, and it's more flexible.
Do you know if it's possible ?
SE ECO EXPERT
Threads: 37
(09.05.2017, 14:41)domotiqa Wrote: (09.05.2017, 13:57)Erwin van der Zwart Wrote: Hi,
Is there a way to do this ?
SE ECO EXPERT
Threads: 6
@ Admin: Is iptables included in the system?
Threads: 37
(22.06.2017, 08:38)admin Wrote: You can enable/disable KNX/IP via event script:
enabled = event.getvalue() and 1 or 0
uci.set('eibd.@eibd[0].knxip=' .. enabled)
uci.commit('eibd')
os.execute('/etc/init.d/eibd restart')
Ok thanks for this great help.
Just a doubt, it will stop KNX communication during few second right also on TP side ?
SE ECO EXPERT
Threads: 41
Yes, but the loss is much shorter compared to reboot
Threads: 37
I have an error
Journal d'erreurs 31.08.2017 23:06:56
User script:2: attempt to index global 'uci' (a nil value)
stack traceback:
User script:2: in main chunk
SE ECO EXPERT
Threads: 41
Add require('uci') before any other code
