Is it possible to enable the IP port 3671 with an icon on the visualisation.
For example, we port forward (without VPN) the 3671 port trhough Internet, but the customer can enable it/ disable it only when we needed maintenance !
Should be cool and "safe" (because it don't stay too much time enable, maybe watchdog...)
SE ECO EXPERT
Why don't you use a IP based forwarding instead of a 0.0.0.0 ?
This way only connections from that location are accepted.
Safest way and you can keep the port open if needed.
Yes you'r wright, however, every internet box doesn't allow this.
In my exemple, the suctomer has the feeleing to control when I can access, and it's more flexible.
Do you know if it's possible ?
SE ECO EXPERT
Is there a way to do this ?
SE ECO EXPERT
