Logic Machine Forum
Need a script for user password change - Printable Version
+--- Thread: Need a script for user password change (/showthread.php?tid=1053)
Pages: 1 2
RE: Need a script for user password change - DGrandes - 10.01.2019
(10.01.2019, 16:30)Daniel. Wrote:
(10.01.2019, 16:17)DGrandes Wrote:
(10.01.2019, 15:55)Daniel. Wrote: I can't find this option, can you guide me where it is?
To change top bar color?
I´ve added in custom css:
body {
  background: #0f0f1e  !important;
In LM? or you found such option somewhere in Safari?  Changing background in LM makes no difference.
Yes, in LM.
If i put this code in commentary, the top bar is gray, but if i put this code, the color is my background blue color.
RE: Need a script for user password change - Daniel - 10.01.2019
OK had to clear browser cache, Will ask dev to check this when next time we will work on it. Thanks for tip.
RE: Need a script for user password change - DGrandes - 11.01.2019
Ok
Thank you
RE: Need a script for user password change - jmir - 06.08.2021
(25.10.2017, 06:40)admin Wrote: 1. Upload attached pass.lp and pass.lua to user directory via FTP (more info here: https://forum.logicmachine.net/showthread.php?tid=85)
2. Make sure that "Enable password for User directory" is set in User access > User access settings
3. Place iframe in visualization, set URL to /user/pass.lp
4. Test with normal user, admin password cannot be changed this way
5. You can edit pass.lp and translate labels and error messages there
Is there any way to add an input box to change Login?
