email with attachement gives image size 0 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: email with attachement gives image size 0 (/showthread.php?tid=1061) Pages:
email with attachement gives image size 0 - gjniewenhuijse - 26.10.2017 Hello, I have a script that sends an email with attached foscam camera snaphots when my doorbell is pushed. That works great for months, but after some time it crashed my lm4 as following: - when my doorbell is pushed i receive an email with size 0 images. every doorbell push i receive that mail with size 0 image - so i try to find the problem and test my code manual with a resident script (sleepinterval 60), the same code as my event-based script Code: require('user.nit_email')
mail({'test@test.nl'}, 'Test', 'Test message.', 'std_camera_2')-So i need to restart my lm4 to solve this issue. Nit_email Code: local from_name = 'HomeLynk'
local settings = {
from = 'test@test.nl',
-- smtp username
--user = '',
-- smtp password
--password = '',
-- smtp server
server = '1.2.3.4',
-- smtp server port
port = 25,
-- enable ssl, required for gmail smtp
--secure = 'sslv23',
local escape = function(v)
return '<' .. tostring(v) .. '>'
-- send an e-mail,
function mail(to, subject, message, att)
-- make sure these settings are correct
local smtp = require('socket.smtp')
if att then
local mime = require('mime')
local ltn12 = require('ltn12')
-- generate attachements
bodyAtt = handleAtt(att, 'start')
bodyAtt = {"",""}
if type(to) ~= 'table' then
to = { to }
for index, email in ipairs(to) do
to[ index ] = escape(email)
settings.source = smtp.message({
headers = {
from = from_name..escape(settings.from),
to = table.concat(to, ', '),
subject = subject,
body = {
--preamble = "Hello Recipient, \r\n" .. "This is your e-mail with a picture attached.",
header = {
['Content-type'] = 'text/html; charset=utf-8',
body = mime.eol(0, message),
bodyAtt[1],bodyAtt[2], -- get attachements if exists (max 2 for now) <---todo:make it dynamic
--epilogue = "That's it folks! :)"
bodyAtt = nil
-- fixup from field
settings.from = escape(settings.from)
settings.rcpt = to
smtp.send(settings)
if att then
handleAtt(att, 'end')
-- std_camera: snapshot camera voordeur
-- std_camera_b: snapshot camera voordeur en achterdeur
function handleAtt(att, handle)
if handle == "start" then
if att == "std_camera" then
require('user.nit_camera')
dst = '/tmp/capture.jpg'
local url = string.format(url_cmdFoscam, cam_voordeur, cam_port, 'snapPicture2', '', cam_usr2, cam_pwd2)
local cmd = string.format('wget -O %q %q', dst, url)
os.execute(cmd)
local attachment = ltn12.source.chain( ltn12.source.file(io.open(dst, 'r')), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
return
headers = {
['Content-type'] = 'image/jpeg; name="image.jpg"',
['Content-disposition'] = 'attachment; filename="image.jpg"',
['Content-transfer-encoding'] = 'BASE64',
body = attachment
elseif att == "std_camera_b" then
dst1 = '/tmp/capture1.jpg'
dst2 = '/tmp/capture2.jpg'
local url1 = string.format(url_cmdFoscam, cam_voordeur, cam_port, 'snapPicture2', '', cam_usr2, cam_pwd2)
local url2 = string.format(url_cmdFoscam, cam_achterdeur, cam_port, 'snapPicture2', '', cam_usr2, cam_pwd2)
local cmd1 = string.format('wget -O %q %q', dst1, url1)
local cmd2 = string.format('wget -O %q %q', dst2, url2)
os.execute(cmd1)
os.execute(cmd2)
local attachment1 = ltn12.source.chain( ltn12.source.file(io.open(dst1, 'r')), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
local attachment2 = ltn12.source.chain( ltn12.source.file(io.open(dst2, 'r')), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
return
headers = {
['Content-type'] = 'image/jpeg; name="image1.jpg"',
['Content-disposition'] = 'attachment; filename="image1.jpg"',
body = attachment1
headers = {
['Content-type'] = 'image/jpeg; name="image2.jpg"',
['Content-disposition'] = 'attachment; filename="image2.jpg"',
body = attachment2
elseif att == "std_camera_2" then
local cmd2 = string.format('wget -O %q %q', dst2, url1)
os.execute(cmd1) -- direct snapshot
cmdFoscam(cam_voordeur, cam_port, 'ptzGotoPresetPoint', '&name=Deur') -- move to frontdoor
os.sleep(20) -- wait for 20 seconds
os.execute(cmd2) -- new snapshot
return
headers = {
body = attachment1
headers = {
body = attachment2
elseif handle == "end" then
os.remove(dst)
os.remove(dst1)
os.remove(dst2)
os.remove(dst1)
os.remove(dst2)
endNit_camera Code: -- snapshot urls
cam_voordeur = '2.2.2.2'
cam_achterdeur = '2.2.2.3'
cam_port = 80
cam_usr = 'user'
cam_pwd = 'password'
cam_usr2 = 'user2'
cam_pwd2 = 'password2'
-- start command urls
url_cmdFoscam = 'http://%s:%s/cgi-bin/CGIProxy.fcgi?cmd=%s%s&usr=%s&pwd=%s'
-- Foscam camera command
function cmdFoscam(iCamera, iPort, iCmd, iParam)
local url, response
url = string.format(url_cmdFoscam, iCamera, iPort, iCmd, iParam, cam_usr, cam_pwd)
if (url) then
require('socket.http')
socket.http.TIMEOUT = 5
response = socket.http.request( url_encode(url) )
return response
endRE: email with attachement gives image size 0 - admin - 26.10.2017 You should use LuaSocket to get a snapshot instead of wget. wget will fail if output file already exist so this might cause a problem with 0 sized attachments. There's no need to save snapshot to /tmp, you can use ltn12.source.string. RE: email with attachement gives image size 0 - gjniewenhuijse - 26.10.2017 (26.10.2017, 09:06)admin Wrote: You should use LuaSocket to get a snapshot instead of wget. wget will fail if output file already exist so this might cause a problem with 0 sized attachments. There's no need to save snapshot to /tmp, you can use ltn12.source.string. can you please give a little example? RE: email with attachement gives image size 0 - admin - 26.10.2017 You already have a function for HTTP requests, just get your snapshot by calling cmdFoscam and then pass the result like this: Code: local snapshot = cmdFoscam(...)
local attachment = ltn12.source.chain( ltn12.source.string(snapshot), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )RE: email with attachement gives image size 0 - DGrandes - 11.07.2018 Hello, I've tried to use this script but I can´t get it to work. ****************************************************************************** function handleAtt(att) if att == "snapshoot" then local snapshoot = 'http://IPCAMERA/cgi-bin/snapshot.cgi?' local attachment = ltn12.source.chain( ltn12.source.string(snapshot), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) ) return { { headers = { ['Content-type'] = 'image/jpeg; name="image.jpg"', ['Content-disposition'] = 'attachment; filename="image.jpg"', ['Content-transfer-encoding'] = 'BASE64', }, body = attachment } } end end The mail function send me a emai with jpg attachment but i can´t see anything. When I use the link 'http://IPCAMERA/cgi-bin/snapshot.cgi?' i have to log in. How can I automatize with code? Thanks RE: email with attachement gives image size 0 - Daniel - 11.07.2018 Try like that 'http://user:password@IPCAMERA/cgi-bin/snapshot.cgi?' RE: email with attachement gives image size 0 - DGrandes - 11.07.2018 (11.07.2018, 11:02)Daniel. Wrote: Try like that It doesn´t work. I´ve tried diferent options and every time ask me user and pass. https://www.ispyconnect.com/man.aspx?n=Dahua RE: email with attachement gives image size 0 - buuuudzik - 11.07.2018 (11.07.2018, 14:12)DGrandes Wrote:(11.07.2018, 11:02)Daniel. Wrote: Try like that You can try like here: https://forum.logicmachine.net/showthread.php?tid=1073&pid=6338#pid6338 Maybe your camera support such params: http://IP_address/cgi-bin/snapshot.cgi?chn=1&u=admin&p=password RE: email with attachement gives image size 0 - DGrandes - 11.07.2018 (11.07.2018, 14:20)buuuudzik Wrote:(11.07.2018, 14:12)DGrandes Wrote:(11.07.2018, 11:02)Daniel. Wrote: Try like that Don´t work.. My camera is IPC-HDBW1320E of Dahua and I try with both url of 'https://www.ispyconnect.com/man.aspx?n=Dahua': It do something strange.. the first time I´ve tried the url it work and don´t ask me the user and pass, but once i use this url it doesn´t work.. I´ve tried with: http://user:pass@CAMERAIP/cgi-bin/snapshot.cgi?1 http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?loginuse=user&loginpas=pass http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?user=user&pass=pass http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?user=user&pwd=pass http://admin:user@CAMERAIP/cgi-bin/snapshot.cgi?u=user&p=pass RE: email with attachement gives image size 0 - mlaudren - 11.07.2018 Can you try to add a fake parameter in the url like timestamp. http://user:pass@CAMERAIP/cgi-bin/snapshot.cgi?1&ts=randomnumber If it worked 1 time, and then fail, maybe there is a caching issue. By adding a parameter that change in the url, it is consider as a new request and will not look in the cache if any. RE: email with attachement gives image size 0 - DGrandes - 12.07.2018 (11.07.2018, 18:21)mlaudren Wrote: Can you try to add a fake parameter in the url like timestamp. Thanks!! this random number works perfectly. But with the script don´t attach the image correctly.. can you help me with the script? Event-Based Script: mail('MyEmail', 'ALERTA', '¡¡¡Alguien en casa!!!', 'captura') Comon Functions: function mail (to, subject, message, att) -- make sure these settings are correct local settings = { -- "from" field, only e-mail must be specified here from = '......', -- smtp username user = '.....', -- smtp password password = '......', -- smtp server server = 'smtp.gmail.com', -- smtp server port port = 465, -- enable tls, required for gmail smtp secure = 'tlsv1_2', } -- make sure these settings are correct local smtp = require('socket.smtp') local escape = function(v) return '<' .. tostring(v) .. '>' end local from_name = '.......' if att then local mime = require('mime') local ltn12 = require('ltn12') -- generate attachements bodyAtt = handleAtt(att) --bodyAtt = handleAtt(att, 'start') else bodyAtt = {"",""} end if type(to) ~= 'table' then to = { to } end for index, email in ipairs(to) do to[ index ] = escape(email) end settings.source = smtp.message({ headers = { from = from_name..escape(settings.from), to = table.concat(to, ', '), subject = subject, }, body = { --preamble = "Hello Recipient, \r\n" .. "This is your e-mail with a picture attached.", { header = { ['Content-type'] = 'text/html; charset=utf-8', }, body = mime.eol(0, message), }, bodyAtt[1],bodyAtt[2], -- get attachements if exists (max 2 for now) <---todo:make it dynamic --epilogue = "That's it folks! "} }) bodyAtt = nil -- fixup from field settings.from = escape(settings.from) settings.rcpt = to smtp.send(settings) end function handleAtt(att) if att == "captura" then local snapshot = 'CAMERAIP'--..math.random(0, 1000000000000) log (snapshot) local attachment = ltn12.source.chain( ltn12.source.string(snapshot), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) ) return { { headers = { ['Content-type'] = 'image/jpeg; name="Captura.jpg"', ['Content-disposition'] = 'attachment; filename="Captura.jpg"', ['Content-transfer-encoding'] = 'BASE64', }, body = attachment } } end end Thanks!!! RE: email with attachement gives image size 0 - DGrandes - 16.08.2018 Hi, I still don't know how to make a snapshoot from my ip camera and save or send it. I have created a DNS to share the url in case you want to test it and help me. The camera is covered by privacy reasons... IP : http://dnspruebacamara.myqnapcloud.com:5858/ user: admin pass: 123456789 I have test it from web explorers (chrome or firefox) and it works perfectly from Them: http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=4561248/snapshot.jpeg where ts=... is a random number that i must change by code, for the navigator not to ask me again the security credencials .... But I can not get it work from the following code: image_type = 'jpeg' image_name_attachment = 'snapshot' source_image_url = 'http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=4561248/snapshot.jpeg' where ts=... is a random number that i must change by code, for the navigator not to ask me again the security credencials --Get remote (from HTTP) image and put image file to HL (will be deleted when end of script) os.execute('wget -O /www/scada/vis/' .. image_name_attachment .. '.' .. image_type .. ' ' .. source_image_url .. '') or I have also tried this other code, and it did not work either: image = socket.http.request(source_image_url) I know that I am doing something wrong, but I dont know what I am missing. Can anyone help me please??? Best regards RE: email with attachement gives image size 0 - admin - 16.08.2018 Your camera uses digest auth mechanism which is not supported by socket.http library. Use this code to get your snapshot: Code: local skthttp = require('socket.http')
local skturl = require('socket.url')
local md5sum = require('encdec').md5
local hash = function(...)
return md5sum(table.concat({...}, ':'))
local parse_header = function(header)
local result = {}
for key, value in (header .. ','):gmatch('(%w+)=(.-),') do
if value:sub(1, 1) == '"' then -- strip quotes
result[ key:lower() ] = value:sub(2, -2)
return result
local make_digest_header = function(headers)
local digest = {}
for _, header in ipairs(headers) do
if not header.unquote then
header[ 2 ] = '"' .. header[ 2 ] .. '"'
digest[ #digest + 1 ] = header[ 1 ] .. '=' .. header[ 2 ]
return 'Digest ' .. table.concat(digest, ', ')
local _request = function(req)
if not req.url then
return nil, 'missing url'
local url = skturl.parse(req.url)
local user, password = url.user, url.password
local sink = req.sink
if not user or not password then
return nil, 'missing credentials in url'
url.user, url.password, url.authority, url.userinfo = nil, nil, nil, nil
req.url = skturl.build(url)
local source
if req.source then
local chunks = {}
local capture = function(chunk)
if chunk then
chunks[ #chunks + 1 ] = chunk
return chunk
local chunk_id = 0
source = function()
chunk_id = chunk_id + 1
return chunks[ chunk_id ]
req.source = ltn12.source.chain(req.source, capture)
req.sink = nil
local body, code, hdrs = skthttp.request(req)
if code == 401 and hdrs['www-authenticate'] then
local ht = parse_header(hdrs['www-authenticate'])
if not ht.realm or not ht.nonce then
return nil, 'missing realm/nonce from response'
local qop = ht.qop
if qop and qop ~= 'auth' then
return nil, 'unsupported qop ' .. tostring(qop)
if ht.algorithm and ht.algorithm:lower() ~= 'md5' then
return nil, 'unsupported algo ' .. tostring(ht.algorithm)
local nc = '00000001'
local cnonce = string.format('%08x', os.time())
local uri = skturl.build({ path = url.path, query = url.query })
local method = req.method or 'GET'
local response = hash(
hash(user, ht.realm, password),
ht.nonce,
nc,
cnonce,
'auth',
hash(method, uri)
req.headers = req.headers or {}
local auth = {
{ 'username', user },
{ 'realm', ht.realm },
{ 'nonce', ht.nonce },
{ 'uri', uri },
{ 'cnonce', cnonce },
{ 'nc', nc, unquote = true },
{ 'qop', 'auth' },
{ 'algorithm', 'MD5' },
{ 'response', response },
if ht.opaque then
table.insert(auth, { 'opaque', ht.opaque })
req.headers.authorization = make_digest_header(auth)
if not req.headers.cookie and hdrs['set-cookie'] then
-- not really correct but enough for httpbin
local cookie = (hdrs['set-cookie'] .. ';'):match('(.-=.-)[;,]')
if cookie then
req.headers.cookie = '$Version: 0; ' .. cookie .. ';'
if req.source then
req.source = source
req.sink = sink
return body, code, hdrs
local request = function(url)
local t = type(url)
if t == 'table' then
return _request(table.clone(url))
elseif t == 'string' then
local req = {}
local _, code, headers = _request({ url = url, sink = ltn12.sink.table(req) })
return table.concat(req), code, headers
url = 'http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=123/snapshot.jpeg'
image, err, hdrs = request(url)RE: email with attachement gives image size 0 - DGrandes - 17.08.2018 Thanks you! It works perfectly Best Regards RE: email with attachement gives image size 0 - Igori - 25.02.2019 Hello! I tried to adapt the script from post 13 to my task. But as a result, I get a file with an image, before which there is a piece of HTML code. In the logs we can see: Code: stest 25.02.2019 13:44:51
* string: <!DOCTYPE html>
<html><head><title>Document Error: Unauthorized</title></head>
<body><h2>Access Error: 401 -- Unauthorized</h2>
<p>Authentication Error</p>
</body>
</html>
����As we can see, the authorization on the camera does not pass, but I still get the image. In order to view it, I only need to remove the html header. So, I have to edit the image before sending it by mail. The solution is simple, but I think it is not quite right Code: a1, a2 = string.find(image,"</html>\r\n")
image = string.sub(image, a2+1)How to solve the problem correctly? Thanks! RE: email with attachement gives image size 0 - admin - 25.02.2019 Your solution is correct, there's nothing else that can be done since the camera response is clearly wrong
RE: email with attachement gives image size 0 - Igori - 25.02.2019 OK. Thank you! RE: email with attachement gives image size 0 - hollywoodperth - 14.08.2019 (16.08.2018, 12:50)I tried to use this code, hopefully I put it in right. Didn\t flag any errors in the log, so that's hopeful.I can't find the url of where the snapshot is sent to... any help??admin Wrote: Your camera uses digest auth mechanism which is not supported by socket.http library. RE: email with attachement gives image size 0 - admin - 15.08.2019 Log what output the server produces. Add this to the end of the script: Code: log(image, err, hdrs)RE: email with attachement gives image size 0 - puntukas - 02.10.2019 In my case I have a file with a silly header: <?xml version="1.0" encoding="UTF-8" ?> <userCheck> <statusValue>401</statusValue> <statusString>Unauthorized</statusString> </userCheck> so I need to add: a1, a2 = string.find(image,"</userCheck>\n") image = string.sub(image, a2+1) to remove them. Thanks. |
