Threads: 97
I have a script that sends an email with attached foscam camera snaphots when my doorbell is pushed.
That works great for months, but after some time it crashed my lm4 as following:
- when my doorbell is pushed i receive an email with size 0 images. every doorbell push i receive that mail with size 0 image
- so i try to find the problem and test my code manual with a resident script (sleepinterval 60), the same code as my event-based script
require (
'user.nit_email' )
mail ({
'test@test.nl' },
'Test' ,
'Test message.' ,
'std_camera_2' )
-I receive every 60 seconds an email, thats correct. But when i stop/deactivate this script i also receive every 60 seconds the email, why?
-So i need to restart my lm4 to solve this issue.
Nit_email
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174
local from_name =
'HomeLynk'
local settings = {
from =
'test@test.nl' ,
server =
'1.2.3.4' ,
port =
25 ,
local escape =
function (
v )
return '<' ..
tostring (
v ) ..
function mail (
to ,
subject ,
message ,
att )
local smtp =
require (
'socket.smtp' )
if att then
local mime =
require (
'mime' )
local ltn12 =
require (
'ltn12' )
bodyAtt =
handleAtt (
att ,
'start' )
bodyAtt = {
if type (
to ) ~=
'table' then
to = {
to }
for index ,
email in ipairs (
to )
do
to [
index ] =
escape (
email )
settings.source =
smtp.message ({
headers = {
from =
from_name..escape (
settings.from ),
to =
table.concat (
to ,
subject =
subject ,
body = {
header = {
'Content-type' ] =
'text/html; charset=utf-8' ,
body =
mime.eol (
0 ,
message ),
bodyAtt [
1 ],
bodyAtt [
2 ],
bodyAtt =
nil
settings.from =
escape (
settings.from )
settings.rcpt =
to
smtp.send (
settings )
if att then
handleAtt (
att ,
'end' )
function handleAtt (
att ,
handle )
if handle ==
"start" then
if att ==
"std_camera" then
require (
'user.nit_camera' )
dst =
'/tmp/capture.jpg'
local url =
string.format (
url_cmdFoscam ,
cam_voordeur ,
cam_port ,
'snapPicture2' ,
cam_usr2 ,
cam_pwd2 )
local cmd =
string.format (
'wget -O %q %q' ,
dst ,
url )
os.execute (
cmd )
local attachment =
ltn12.source.chain (
ltn12.source.file (
io.open (
dst ,
'r' )),
ltn12.filter.chain (
mime.encode (
'base64' ),
mime.wrap ()) )
return
headers = {
'Content-type' ] =
'image/jpeg; name="image.jpg"' ,
'Content-disposition' ] =
'attachment; filename="image.jpg"' ,
'Content-transfer-encoding' ] =
'BASE64' ,
body =
elseif att ==
"std_camera_b" then
require (
'user.nit_camera' )
dst1 =
'/tmp/capture1.jpg'
dst2 =
'/tmp/capture2.jpg'
local url1 =
string.format (
url_cmdFoscam ,
cam_voordeur ,
cam_port ,
'snapPicture2' ,
cam_usr2 ,
cam_pwd2 )
local url2 =
string.format (
url_cmdFoscam ,
cam_achterdeur ,
cam_port ,
'snapPicture2' ,
cam_usr2 ,
cam_pwd2 )
local cmd1 =
string.format (
'wget -O %q %q' ,
dst1 ,
url1 )
local cmd2 =
string.format (
'wget -O %q %q' ,
dst2 ,
url2 )
os.execute (
cmd1 )
os.execute (
cmd2 )
local attachment1 =
ltn12.source.file (
io.open (
dst1 ,
'r' )),
mime.encode (
'base64' ),
mime.wrap ()) )
local attachment2 =
ltn12.source.file (
io.open (
dst2 ,
'r' )),
mime.encode (
'base64' ),
mime.wrap ()) )
return
headers = {
'Content-type' ] =
'image/jpeg; name="image1.jpg"' ,
'attachment; filename="image1.jpg"' ,
'BASE64' ,
body =
attachment1
headers = {
'Content-type' ] =
'image/jpeg; name="image2.jpg"' ,
'attachment; filename="image2.jpg"' ,
'BASE64' ,
body =
attachment2
elseif att ==
"std_camera_2" then
require (
'user.nit_camera' )
dst1 =
'/tmp/capture1.jpg'
dst2 =
'/tmp/capture2.jpg'
local url1 =
string.format (
url_cmdFoscam ,
cam_voordeur ,
cam_port ,
'snapPicture2' ,
cam_usr2 ,
cam_pwd2 )
local cmd1 =
string.format (
'wget -O %q %q' ,
dst1 ,
url1 )
local cmd2 =
string.format (
'wget -O %q %q' ,
dst2 ,
url1 )
os.execute (
cmd1 )
cmdFoscam (
cam_voordeur ,
cam_port ,
'ptzGotoPresetPoint' ,
'&name=Deur' )
os.sleep (
20 )
os.execute (
cmd2 )
local attachment1 =
ltn12.source.file (
io.open (
dst1 ,
'r' )),
mime.encode (
'base64' ),
mime.wrap ()) )
local attachment2 =
ltn12.source.file (
io.open (
dst2 ,
'r' )),
mime.encode (
'base64' ),
mime.wrap ()) )
return
headers = {
'Content-type' ] =
'BASE64' ,
body =
attachment1
headers = {
'Content-type' ] =
'BASE64' ,
body =
attachment2
elseif handle ==
"end" then
if att ==
"std_camera" then
os.remove (
dst )
elseif att ==
"std_camera_b" then
os.remove (
dst1 )
os.remove (
dst2 )
elseif att ==
"std_camera_2" then
os.remove (
dst1 )
os.remove (
dst2 )
Nit_camera
cam_voordeur =
'2.2.2.2'
cam_achterdeur =
'2.2.2.3'
cam_port =
80
cam_usr =
'user'
cam_pwd =
'password'
cam_usr2 =
'user2'
cam_pwd2 =
'password2'
url_cmdFoscam =
'http://%s:%s/cgi-bin/CGIProxy.fcgi?cmd=%s%s&usr=%s&pwd=%s'
function cmdFoscam (
iCamera ,
iPort ,
iCmd ,
iParam )
local url ,
response
url =
string.format (
url_cmdFoscam ,
iCamera ,
iPort ,
iCmd ,
iParam ,
cam_usr ,
cam_pwd )
if (
url )
then
require (
'socket.http' )
socket.http.TIMEOUT =
5
response =
socket.http.request (
url_encode (
url ) )
return response
Threads: 43
You should use LuaSocket to get a snapshot instead of wget. wget will fail if output file already exist so this might cause a problem with 0 sized attachments. There's no need to save snapshot to /tmp, you can use ltn12.source.string.
Threads: 97
(26.10.2017, 09:06) admin Wrote: You should use LuaSocket to get a snapshot instead of wget. wget will fail if output file already exist so this might cause a problem with 0 sized attachments. There's no need to save snapshot to /tmp, you can use ltn12.source.string.
can you please give a little example?
Threads: 43
You already have a function for HTTP requests, just get your snapshot by calling cmdFoscam and then pass the result like this:
local snapshot =
cmdFoscam (...)
local attachment =
ltn12.source.string (
snapshot ),
mime.encode (
'base64' ),
mime.wrap ()) )
Threads: 31
11.07.2018, 10:51
(This post was last modified: 11.07.2018, 10:51 by DGrandes .)
I've tried to use this script but I can´t get it to work.
function handleAtt(att)
if att == "snapshoot" then
local snapshoot = 'http://IPCAMERA/cgi-bin/snapshot.cgi?'
local attachment = ltn12.source.chain( ltn12.source.string(snapshot), ltn12.filter.chain(mime.encode('base64'), mime.wrap()) )
return
headers = {
['Content-type'] = 'image/jpeg; name="image.jpg"',
['Content-disposition'] = 'attachment; filename="image.jpg"',
['Content-transfer-encoding'] = 'BASE64',
body = attachment
The mail function send me a emai with jpg attachment but i can´t see anything.
When I use the link 'http://IPCAMERA/cgi-bin/snapshot.cgi?' i have to log in. How can I automatize with code?
Threads: 28
Try like that
'http://user:password@IPCAMERA/cgi-bin/snapshot.cgi?'
Threads: 31
(11.07.2018, 11:02) Daniel. Wrote: Try like that
It doesn´t work.
I´ve tried diferent options and every time ask me user and pass.
https://www.ispyconnect.com/man.aspx?n=Dahua
Threads: 161
(11.07.2018, 14:12) DGrandes Wrote: (11.07.2018, 11:02) Daniel. Wrote: Try like that
It doesn´t work.
You can try like here:
https://forum.logicmachine.net/showthrea...38#pid6338
Maybe your camera support such params:
http://IP_address/cgi-bin/snapshot.cgi?c...p=password
Done is better than perfect
Threads: 31
11.07.2018, 15:07
(This post was last modified: 11.07.2018, 15:20 by DGrandes .)
(11.07.2018, 14:20) buuuudzik Wrote: (11.07.2018, 14:12) DGrandes Wrote: (11.07.2018, 11:02) Daniel. Wrote: Try like that
It doesn´t work.
Don´t work..
My camera is IPC-HDBW1320E of Dahua and I try with both url of 'https://www.ispyconnect.com/man.aspx?n=Dahua':
It do something strange.. the first time I´ve tried the url it work and don´t ask me the user and pass, but once i use this url it doesn´t work..
I´ve tried with:
http://user :pass@CAMERAIP/cgi-bin/snapshot.cgi?1
http://admin :user@CAMERAIP/cgi-bin/snapshot.cgi?loginuse=user&loginpas=pass
http://admin :user@CAMERAIP/cgi-bin/snapshot.cgi?user=user&pass=pass
http://admin :user@CAMERAIP/cgi-bin/snapshot.cgi?user=user&pwd=pass
http://admin :user@CAMERAIP/cgi-bin/snapshot.cgi?u=user&p=pass
Threads: 3
Can you try to add a fake parameter in the url like timestamp.
http://user :pass@CAMERAIP/cgi-bin/snapshot.cgi?1&ts=randomnumber
If it worked 1 time, and then fail, maybe there is a caching issue. By adding a parameter that change in the url, it is consider as a new request and will not look in the cache if any.
Threads: 31
12.07.2018, 08:20
(This post was last modified: 12.07.2018, 08:20 by DGrandes .)
(11.07.2018, 18:21) mlaudren Wrote: Can you try to add a fake parameter in the url like timestamp.
Thanks!! this random number works perfectly. But with the script don´t attach the image correctly.. can you help me with the script?
Event-Based Script:
mail('MyEmail', 'ALERTA', '¡¡¡Alguien en casa!!!', 'captura')
Comon Functions:
function mail (to, subject, message, att)
local settings = {
from = '......',
-- smtp username
user = '.....',
-- smtp password
password = '......',
-- smtp server
server = 'smtp.gmail.com',
-- smtp server port
port = 465,
-- enable tls, required for gmail smtp
secure = 'tlsv1_2',
local escape = function(v)
return '<' .. tostring(v) .. '>'
local from_name = '.......'
if att then
local mime = require('mime')
local ltn12 = require('ltn12')
-- generate attachements
bodyAtt = handleAtt(att) --bodyAtt = handleAtt(att, 'start')
bodyAtt = {"",""}
if type(to) ~= 'table' then
to = { to }
for index, email in ipairs(to) do
to[ index ] = escape(email)
headers = {
from = from_name..escape(settings.from),
to = table.concat(to, ', '),
subject = subject,
body = {
--preamble = "Hello Recipient, \r\n" .. "This is your e-mail with a picture attached.",
header = {
['Content-type'] = 'text/html; charset=utf-8',
body = mime.eol(0, message),
bodyAtt[1],bodyAtt[2], -- get attachements if exists (max 2 for now) <---todo:make it dynamic
--epilogue = "That's it folks!
bodyAtt = nil
-- fixup from field
settings.from = escape(settings.from)
settings.rcpt = to
smtp.send(settings)
if att == "captura" then
local snapshot = 'CAMERAIP'--..math.random(0, 1000000000000)
log (snapshot)
return
headers = {
['Content-type'] = 'image/jpeg; name="Captura.jpg"',
['Content-disposition'] = 'attachment; filename="Captura.jpg"',
body = attachment
Thanks!!!
Threads: 31
I still don't know how to make a snapshoot from my ip camera and save or send it.
I have created a DNS to share the url in case you want to test it and help me. The camera is covered by privacy reasons...
IP :
http://dnspruebacamara.myqnapcloud.com:5858/
user: admin
pass: 123456789
I have test it from web explorers (chrome or firefox) and it works perfectly from Them:
http://admin:123456789@dnspruebacamara.m...pshot.jpeg
where ts=... is a random number that i must change by code, for the navigator not to ask me again the security credencials
.... But I can not get it work from the following code:
image_type = 'jpeg'
image_name_attachment = 'snapshot'
source_image_url = 'http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=4561248/snapshot.jpeg'
--Get remote (from HTTP) image and put image file to HL (will be deleted when end of script)
os.execute('wget -O /www/scada/vis/' .. image_name_attachment .. '.' .. image_type .. ' ' .. source_image_url .. '')
or I have also tried this other code, and it did not work either:
image = socket.http.request(source_image_url)
I know that I am doing something wrong, but I dont know what I am missing.
Can anyone help me please???
Best regards
Threads: 43
Your camera uses digest auth mechanism which is not supported by socket.http library.
Use this code to get your snapshot:
local skthttp =
require (
'socket.http' )
local skturl =
require (
'socket.url' )
local ltn12 =
require (
'ltn12' )
local md5sum =
require (
'encdec' ).
md5
local hash =
function (...)
return md5sum (
table.concat ({...},
local parse_header =
function (
header )
local result = {}
for key ,
value in (
header ..
gmatch (
'(%w+)=(.-),' )
do
if value :
sub (
1 ,
1 ) ==
'"' then
result [
key :
lower () ] =
value :
sub (
2 , -
2 )
result [
key :
lower () ] =
value
return result
local make_digest_header =
function (
headers )
local digest = {}
for _ ,
header in ipairs (
headers )
do
if not header.unquote then
header [
2 ] =
header [
2 ] ..
digest [ #
digest +
1 ] =
header [
1 ] ..
header [
2 ]
return 'Digest ' ..
table.concat (
digest ,
local _request =
function (
req )
if not req.url then
return nil ,
'missing url'
local url =
skturl.parse (
req.url )
local user ,
password =
url.user ,
url.password
local sink =
req.sink
if not user or not password then
return nil ,
'missing credentials in url'
url.user ,
url.password ,
url.authority ,
url.userinfo =
nil ,
nil ,
nil ,
nil
req.url =
skturl.build (
url )
local source
if req.source then
local chunks = {}
local capture =
function (
chunk )
if chunk then
chunks [ #
chunks +
1 ] =
chunk
return chunk
local chunk_id =
source =
function ()
chunk_id =
chunk_id +
return chunks [
chunk_id ]
req.source =
req.source ,
capture )
req.sink =
nil
local body ,
code ,
hdrs =
skthttp.request (
req )
if code ==
401 and hdrs [
'www-authenticate' ]
then
local ht =
parse_header (
hdrs [
'www-authenticate' ])
if not ht.realm or not ht.nonce then
return nil ,
'missing realm/nonce from response'
local qop =
ht.qop
if qop and qop ~=
'auth' then
return nil ,
'unsupported qop ' ..
tostring (
qop )
if ht.algorithm and ht.algorithm :
lower () ~=
'md5' then
return nil ,
'unsupported algo ' ..
tostring (
ht.algorithm )
local nc =
'00000001'
local cnonce =
string.format (
'%08x' ,
os.time ())
local uri =
skturl.build ({
path =
url.path ,
query =
url.query })
local method =
req.method or 'GET'
local response =
hash (
hash (
user ,
ht.realm ,
password ),
ht.nonce ,
nc ,
cnonce ,
'auth' ,
hash (
method ,
uri )
req.headers =
req.headers or {}
local auth = {
'username' ,
user },
'realm' ,
ht.realm },
'nonce' ,
ht.nonce },
'uri' ,
uri },
'cnonce' ,
cnonce },
'nc' ,
nc ,
unquote =
true },
'qop' ,
'auth' },
'algorithm' ,
'MD5' },
'response' ,
response },
if ht.opaque then
table.insert (
auth , {
'opaque' ,
ht.opaque })
req.headers.authorization =
make_digest_header (
auth )
if not req.headers.cookie and hdrs [
'set-cookie' ]
then
local cookie = (
hdrs [
'set-cookie' ] ..
match (
if cookie then
req.headers.cookie =
'$Version: 0; ' ..
cookie ..
if req.source then
req.source =
source
req.sink =
sink
body ,
code ,
hdrs =
skthttp.request (
req )
return body ,
code ,
hdrs
local request =
function (
url )
local t =
type (
url )
if t ==
'table' then
return _request (
table.clone (
url ))
elseif t ==
'string' then
local req = {}
local _ ,
code ,
headers =
_request ({
url =
url ,
sink =
ltn12.sink.table (
req ) })
return table.concat (
req ),
code ,
headers
url =
'http://admin:123456789@dnspruebacamara.myqnapcloud.com:5858/cgi-bin/snapshot.cgi?1&ts=123/snapshot.jpeg'
image ,
err ,
hdrs =
request (
url )
Threads: 31
Thanks you!
It works perfectly
Best Regards
Threads: 2
25.02.2019, 10:58
(This post was last modified: 25.02.2019, 11:00 by Igori .)
Hello!
I tried to adapt the script from post 13 to my task. But as a result, I get a file with an image, before which there is a piece of HTML code. In the logs we can see:
stest 25.02.2019 13 :
44 :
51
string : <!
DOCTYPE html >
html ><
head ><
title >
Document Error :
Unauthorized </
title ></
head >
body ><
h2 >
Access Error :
401
p >
Authentication Error </
p >
body >
html >
As we can see, the authorization on the camera does not pass, but I still get the image. In order to view it, I only need to remove the html header.
So, I have to edit the image before sending it by mail. The solution is simple, but I think it is not quite right
a1 ,
a2 =
string.find (
image ,
"</html>\r\n" )
image =
string.sub (
image ,
a2 +
1 )
How to solve the problem correctly?
Thanks!
Threads: 43
Your solution is correct, there's nothing else that can be done since the camera response is clearly wrong
Threads: 2
Threads: 1
(16.08.2018, 12:50) I tried to use this code, hopefully I put it in right. Didn\t flag any errors in the log, so that's hopeful.I can't find the url of where the snapshot is sent to... any help??admin Wrote: Your camera uses digest auth mechanism which is not supported by socket.http library.
local skthttp =
require (
'socket.http' )
local skturl =
require (
'socket.url' )
local ltn12 =
require (
'ltn12' )
local md5sum =
require (
'encdec' ).
md5
local hash =
function (...)
return md5sum (
function (
header )
local result = {}
for key ,
value in (
header ..
gmatch (
'(%w+)=(.-),' )
do
if value :
sub (
1 ,
1 ) ==
'"' then
result [
key :
lower () ] =
value :
sub (
2 , -
2 )
result [
key :
lower () ] =
value
return result
function (
headers )
local digest = {}
for _ ,
header in ipairs (
headers )
do
header [
2 ] =
header [
2 ] ..
digest [ #
digest +
1 ] =
header [
1 ] ..
header [
2 ]
return 'Digest ' ..
table.concat (
digest ,
local _request =
function (
req )
if not req.url then
return nil ,
'missing url'
local url =
skturl.parse (
req.url )
local user ,
password =
url.user ,
url.password
return nil ,
url.user ,
url.password ,
url.authority ,
url.userinfo =
nil ,
nil ,
nil ,
nil
req.url =
skturl.build (
url )
local source
if req.source then
local chunks = {}
local capture =
function (
chunk )
if chunk then
chunks [ #
chunks +
1 ] =
chunk
return chunk
local chunk_id =
source =
function ()
chunk_id =
chunk_id +
return chunks [
chunk_id ]
req.source =
req.source ,
capture )
local body ,
code ,
hdrs =
skthttp.request (
req )
if code ==
401 and hdrs [
then
local ht =
parse_header (
hdrs [
return nil ,
if ht.qop ~=
'auth' then
return nil ,
tostring (
ht.qop )
lower () ~=
'md5' then
return nil ,
tostring (
ht.algorithm )
local nc =
'00000001'
local cnonce =
string.format (
'%08x' ,
os.time ())
local uri =
skturl.build ({
path =
url.path ,
query =
url.query })
local method =
req.method or 'GET'
local response =
hash (
hash (
user ,
ht.realm ,
password ),
ht.nonce ,
nc ,
cnonce ,
'auth' ,
hash (
method ,
uri )
req.headers =
req.headers or {}
local auth = {
'username' ,
user },
'realm' ,
ht.realm },
'nonce' ,
ht.nonce },
'uri' ,
uri },
'cnonce' ,
cnonce },
'nc' ,
nc ,
unquote =
true },
'qop' ,
'auth' },
'algorithm' ,
'MD5' },
'response' ,
response },
if ht.opaque then
table.insert (
auth , {
'opaque' ,
ht.opaque })
auth )
'set-cookie' ]
then
local cookie = (
hdrs [
'set-cookie' ] ..
match (
if cookie then
'$Version: 0; ' ..
cookie ..
if req.source then
req.source =
source
body ,
code ,
hdrs =
skthttp.request (
req )
return body ,
code ,
hdrs
local request =
function (
url )
local t =
type (
url )
if t ==
'table' then
return _request (
table.clone (
url ))
elseif t ==
'string' then
local req = {}
local _ ,
code ,
headers =
_request ({
url =
url ,
sink =
ltn12.sink.table (
req ) })
req ),
code ,
headers
url =
image ,
err ,
hdrs =
request (
url )
Threads: 43
Log what output the server produces. Add this to the end of the script:
Threads: 11
In my case I have a file with a silly header:
<?xml version="1.0" encoding="UTF-8" ?>
<userCheck>
<statusValue>401</statusValue>
<statusString>Unauthorized</statusString>
</userCheck>
so I need to add:
a1, a2 = string.find(image,"</userCheck>\n")
image = string.sub(image, a2+1)
to remove them.
