Logic Machine Forum
Modbus TCP slave example - Printable Version
+--- Thread: Modbus TCP slave example (/showthread.php?tid=181)
Pages: 1 2
RE: Modbus TCP slave example - rw_echo - 16.03.2023
The source code is as follows:
https://forum.logicmachine.net/showthread.php?tid=181&pid=3233#pid3233:~:text=if%20not%20mb%20then,loop(0.1)
Lm as modbus rtu slave:
1.I need to add the 'inputregisters' and' discreteinputs' mapping list of the source code. How should I change the code?
2.Another problem is that if the value of the group address "1/1/1" of dt.float16 is 23 and the mapped register address value is 2300, how do you make their values correspond?
RE: Modbus TCP slave example - admin - 17.03.2023
Universal script has been update with RTU support: https://forum.logicmachine.net/showthread.php?tid=4288
