schneider wiser/spacelynk issues - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Hardware (https://forum.logicmachine.net/forumdisplay.php?fid=12) +--- Thread: schneider wiser/spacelynk issues (/showthread.php?tid=2270) |
schneider wiser/spacelynk issues - gdimaria - 09.10.2019 it is the second schneider that behaves in the same way: I cannot restore any backups, it does not accept any changes to the project (after a while it returns as before), it does not allow me to reset to factory conditions nor firmware update. Both machines have been working for 4/5 years in different places with different customers. Is it a memory problem? Are they to be replaced? RE: schneider wiser/spacelynk issues - Erwin van der Zwart - 09.10.2019 Hi, Sounds like your SD card is switched to read-only. Your SD card probably needs to be replaced. See: For spaceLynk: https://download.schneider-electric.com/files?p_enDocType=Application+solutions&p_File_Name=AN2_001_How_to_flash_microSD_card_spaceLYnk.zip&p_Doc_Ref=AN2_001_SL For W4K: https://download.schneider-electric.com/files?p_enDocType=Application+solutions&p_File_Name=AN2_001_How_to_flash_microSD_card_W4K.zip&p_Doc_Ref=AN2_001 BR, Erwin RE: schneider wiser/spacelynk issues - gdimaria - 10.10.2019 (09.10.2019, 08:19)Ok, I will check... but how is possible the SD card switch to read-ony by itself?BRPeppeErwin van der Zwart Wrote: Hi, |
