schneider wiser/spacelynk issues
it is the second schneider that behaves in the same way:
I cannot restore any backups, it does not accept any changes to the project (after a while it returns as before), it does not allow me to reset to factory conditions nor firmware update. Both machines have been working for 4/5 years in different places with different customers. Is it a memory problem? Are they to be replaced?
Sounds like your SD card is switched to read-only. Your SD card probably needs to be replaced.
See:
For spaceLynk: https://download.schneider-electric.com/...AN2_001_SL
For W4K: https://download.schneider-electric.com/...ef=AN2_001
(09.10.2019, 08:19)Ok, I will check... but how is possible the SD card switch to read-ony by itself?BRPeppeErwin van der Zwart Wrote: Hi,
See:
