zerotier for connection between 2 LMs - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: zerotier for connection between 2 LMs (/showthread.php?tid=2957) |
zerotier for connection between 2 LMs - bmodeco - 04.11.2020 Hi, I will end up having 2 KNX-sites (home/office) running both an LM. I would like to trigger some groupadresses from one site to another. Both sites have an independent VPN-server (openvpn). I was thinking to (don't know if this is possible through a script): - start openvpn and connect - send remote command - close vpn (no need to keep the vpn open all day) From what i understand it should also be possible with the zerotier when i connect both LMs to the same network. One question with this: do they retain their IP-adres after reboot (is it fixed)? For obvious reasons i do not want to open any KNX-ports on the router... Any ideas about this? Thanks, Bart RE: zerotier for connection between 2 LMs - Daniel - 04.11.2020 In ZeroTier settings you can assign IP for a device. RE: zerotier for connection between 2 LMs - bmodeco - 04.11.2020 (04.11.2020, 12:18)Daniel. Wrote: In ZeroTier settings you can assign IP for a device. Thanks Daniel. The zerotier will be the best solution then. Is it still in beta? RE: zerotier for connection between 2 LMs - Daniel - 04.11.2020 Yes but nearly there. |
