zerotier for connection between 2 LMs
I will end up having 2 KNX-sites (home/office) running both an LM.
I would like to trigger some groupadresses from one site to another. Both sites have an independent VPN-server (openvpn).
I was thinking to (don't know if this is possible through a script):
- start openvpn and connect
- send remote command
- close vpn (no need to keep the vpn open all day)
From what i understand it should also be possible with the zerotier when i connect both LMs to the same network.
One question with this: do they retain their IP-adres after reboot (is it fixed)?
For obvious reasons i do not want to open any KNX-ports on the router...
Any ideas about this?
Thanks,
Bart
In ZeroTier settings you can assign IP for a device.
(04.11.2020, 12:18)Daniel. Wrote: In ZeroTier settings you can assign IP for a device.
Thanks Daniel.
The zerotier will be the best solution then.
Is it still in beta?
Yes but nearly there.
