Logic Machine 5 - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Gateway (https://forum.logicmachine.net/forumdisplay.php?fid=10) +--- Thread: Logic Machine 5 (/showthread.php?tid=3294) |
Logic Machine 5 - ATEF KOUKA - 09.04.2021 logic machine complains after a power cut but I see it on the network and I can ping it. RE: Logic Machine 5 - Daniel - 09.04.2021 I assume you tried reboot. You could be extremely unlucky and LM could perform auto save while power cut happened and it could couse some system files corruption. If nothing will help then you will need to re-flash the card. RE: Logic Machine 5 - ATEF KOUKA - 12.04.2021 (09.04.2021, 09:50)ATEF KOUKA Wrote: logic machine complains after a power cut but I see it on the network and I can ping it. Thank you very much but how can I re-flash the card. RE: Logic Machine 5 - Daniel - 12.04.2021 https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ RE: Logic Machine 5 - ATEF KOUKA - 15.04.2021 (12.04.2021, 10:08)Daniel. Wrote: https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ thank you RE: Logic Machine 5 - ATEF KOUKA - 02.09.2021 (15.04.2021, 08:32)ATEF KOUKA Wrote:BONJOUR(12.04.2021, 10:08)Daniel. Wrote: https://openrb.com/reflash-logicmachine3-and-streaming-player-software/ EST CE QUE LA MEME MISE A JOUR POUR LES SPACE LYNK HELLO Is the same update for Space Lynk RE: Logic Machine 5 - admin - 03.09.2021 (02.09.2021, 12:16)ATEF KOUKA Wrote: BONJOURFor new CPU use this image: http://dl.openrb.com/recovery-imx6-1g.img.gz The recovery procedure is the same. |
