Logic Machine 5
logic machine complains after a power cut but I see it on the network and I can ping it.
I assume you tried reboot. You could be extremely unlucky and LM could perform auto save while power cut happened and it could couse some system files corruption. If nothing will help then you will need to re-flash the card.
(09.04.2021, 09:50)ATEF KOUKA Wrote: logic machine complains after a power cut but I see it on the network and I can ping it.
Thank you very much but how can I re-flash the card.
https://openrb.com/reflash-logicmachine3...-software/
(12.04.2021, 10:08)Daniel. Wrote: https://openrb.com/reflash-logicmachine3...-software/
thank you
Merci
BONJOUR
 EST CE QUE LA MEME MISE A JOUR POUR LES SPACE LYNK
HELLO
Is the same update for Space Lynk
(02.09.2021, 12:16)ATEF KOUKA Wrote: BONJOUR
HELLO
For new CPU use this image: http://dl.openrb.com/recovery-imx6-1g.img.gz
The recovery procedure is the same.
