Scheduled script doesn't work - Printable Version
+--- Thread: Scheduled script doesn't work (/showthread.php?tid=358)
Scheduled script doesn't work - gjniewenhuijse - 27.07.2016
I have more scheduled (cron) scripts that works great. But when i add a new scheduled script its never executed.
I checked it with the following code: log('executed').
See attached image for my schedule settings
Firmware: 20151125
RE: Scheduled script doesn't work - Habib - 27.07.2016
I had the same problem. Please try to reboot your system, it helps me in this case.
RE: Scheduled script doesn't work - gjniewenhuijse - 27.07.2016
(27.07.2016, 11:23)Habib Wrote: Hi,
Reboot doesn't solve it.
and a cold boot (power Off and on)?
I think it's excactly the same problem than mine, see this post: http://forum.logicmachine.net/showthread.php?tid=337
In my case it's working only if I switch off the system and on again. admin means in my case, there is no difference between hot and cold boot.
RE: Scheduled script doesn't work - admin - 27.07.2016
Have you tried installing RC firmware? There's no difference between cold boot and software reboot.
(27.07.2016, 11:50)admin Wrote: Have you tried installing RC firmware? There's no difference between cold boot and software reboot.
I installed the latest RC firmware from the forum, now it works. But the version showed is: 20151125 (also after browser close/refresh/other browser)
Hmm, double check the firmware file. Resulting version should start with 201607. It might be an SD card issue, can you try installing a new one? Follow this guide: http://openrb.com/reflash-logicmachine3-and-streaming-player-software/
(27.07.2016, 12:49)admin Wrote: Hmm, double check the firmware file. Resulting version should start with 201607. It might be an SD card issue, can you try installing a new one? Follow this guide: http://openrb.com/reflash-logicmachine3-and-streaming-player-software/
This is a device with already a replaced sd card. I installed the firmware file again and now its updated.
