1 script 200 Rooms - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: 1 script 200 Rooms (/showthread.php?tid=3990) |
1 script 200 Rooms - Stuart2000 - 12.04.2022 Hi, I have this script, but 200 rooms. What will the script look like when it is based on finding room number. 1 script for all my rooms? Instead of 200 scripts. The room number is 1.203 in this case. XXXXX_XZXX - XXX.XXX-SQXXX-room_Setpoint_XXX this line can be different.. 433011_XZ30 - 360.004-SQ401-1.203_Setpoint_mp4 Comp_max_input1 = grp.getvalue('1.203-SX601_Cooling_C') Comp_max_input2 = grp.getvalue('1.203-RB601_SQ_C') Comp_max_output = '433011_XZ30 - 360.004-SQ401-1.203_Setpoint_mp4' maxout = math.max(Comp_max_input1,Comp_max_input2) grp.checkwrite(Comp_max_output, maxout) RE: 1 script 200 Rooms - admin - 12.04.2022 Do you follow a specific addressing scheme where other addresses can be calculated from the source address? Something like 1/1/203 - input1, 1/2/203 - input2, 3/2/203 - output. RE: 1 script 200 Rooms - Stuart2000 - 12.04.2022 (12.04.2022, 08:55)admin Wrote: Do you follow a specific addressing scheme where other addresses can be calculated from the source address? No. RE: 1 script 200 Rooms - admin - 12.04.2022 Is there some rule how other names can be found from the source name? Another option is to tag objects with multiple tags (something like "input", "room_1_203") and find other objects using these tag. Or you can create a lookup table with all addresses that the script will use to find input/output objects. RE: 1 script 200 Rooms - Stuart2000 - 12.04.2022 (12.04.2022, 09:17)admin Wrote: Is there some rule how other names can be found from the source name? Another option is to tag objects with multiple tags (something like "input", "room_1_203") and find other objects using these tag. Or you can create a lookup table with all addresses that the script will use to find input/output objects. No this is what I have. What is the simplies way to do this with what i got? RE: 1 script 200 Rooms - admin - 13.04.2022 Here's a solution with a lookup table. All input objects should have a common tag to which an event script is attached. Fill the addrlist table with group addresses as needed. Each entry is a single room (input 1/2 + output). The script finds the second input based on the group address that triggered the script and writes the maximum between two inputs to the output object. Code: addrlist = {
input1 = '1/1/1',
input2 = '1/1/2',
output = '1/1/3',
input1 = '1/1/4',
input2 = '1/1/5',
output = '1/1/6',
input1 = '1/2/4',
input2 = '1/2/5',
output = '1/2/6',
for _, addrs in ipairs(addrlist) do
if event.dst == addrs.input1 then
altinput = addrs.input2
output = addrs.output
break
elseif event.dst == addrs.input2 then
altinput = addrs.input1
break
if altinput and output then
value1 = event.getvalue()
value2 = grp.getvalue(altinput)
grp.checkwrite(output, math.max(value1, value2))
endRE: 1 script 200 Rooms - Stuart2000 - 19.04.2022 (13.04.2022, 11:21)admin Wrote: Here's a solution with a lookup table. All input objects should have a common tag to which an event script is attached. Fill the addrlist table with group addresses as needed. Each entry is a single room (input 1/2 + output).TNX |
