Sunrise/Sunset Timer - Printable Version
+--- Thread: Sunrise/Sunset Timer (/showthread.php?tid=4034)
Sunrise/Sunset Timer - vmic - 05.05.2022
Hi!
I created a schedule tiimer for turning On or Off some lights via KNX and I used the Sunrise Sunset schedule. I found out that it didn't worked for me. I set the time zone to LM Utilities / Date and Time but the lights didn't turned off in the monring (during sunrise).
What am I doing wrong? Is it something else I am missing?
RE: Sunrise/Sunset Timer - Daniel - 05.05.2022
Make sure that the scheduler is enabled and log the object to see if scheduler sent it or not.
RE: Sunrise/Sunset Timer - vmic - 05.05.2022
(05.05.2022, 16:34)Daniel Wrote: Make sure that the scheduler is enabled and log the object to see if scheduler sent it or no
Thank you for your reply
How am I going to log the object please?
RE: Sunrise/Sunset Timer - admin - 06.05.2022
Enable "Log" option for the object that is attached to the scheduler. Also check that you don't have the same object set in the "Scheduler on/off object".
RE: Sunrise/Sunset Timer - vmic - 06.05.2022
(06.05.2022, 08:05)admin Wrote: Enable "Log" option for the object that is attached to the scheduler. Also check that you don't have the same object set in the "Scheduler on/off object".
ok thank you very much for your reply
