Sunrise/Sunset Timer
Hi!
I created a schedule tiimer for turning On or Off some lights via KNX and I used the Sunrise Sunset schedule. I found out that it didn't worked for me. I set the time zone to LM Utilities / Date and Time but the lights didn't turned off in the monring (during sunrise).
What am I doing wrong? Is it something else I am missing?
Make sure that the scheduler is enabled and log the object to see if scheduler sent it or not.
(05.05.2022, 16:34)Daniel Wrote: Make sure that the scheduler is enabled and log the object to see if scheduler sent it or no
Thank you for your reply
How am I going to log the object please?
Enable "Log" option for the object that is attached to the scheduler. Also check that you don't have the same object set in the "Scheduler on/off object".
(06.05.2022, 08:05)admin Wrote: Enable "Log" option for the object that is attached to the scheduler. Also check that you don't have the same object set in the "Scheduler on/off object".
ok thank you very much for your reply
