Android APP using HTTPS - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Application Store (https://forum.logicmachine.net/forumdisplay.php?fid=11) +--- Thread: Android APP using HTTPS (/showthread.php?tid=4272) |
Android APP using HTTPS - jmir - 29.09.2022 Hi, Is it possible to use Android APP using, for example 4433 port? I've tryied and it opens a white page... I've done the same test using web browser and it works fine.... Configuration on the app is like this: IP address: XXX.XXX.XXX.XXX:4433 HTTPS: YES RE: Android APP using HTTPS - admin - 29.09.2022 Install LM SSL app (https://forum.logicmachine.net/showthread.php?tid=3309) and provide domain name instead of IP address in the app. HTTPS port is 443, there's no need to specify it directly. RE: Android APP using HTTPS - jmir - 29.09.2022 (29.09.2022, 13:33)admin Wrote: Install LM SSL app (https://forum.logicmachine.net/showthread.php?tid=3309) and provide domain name instead of IP address in the app. HTTPS port is 443, there's no need to specify it directly. Hi, I'm using domain name (from dyndns) and I need to use external port 4433 (it's redirected to 443 on LM because external 443 is used by another service). Thanks. RE: Android APP using HTTPS - Daniel - 29.09.2022 It looks like google started to block https connections without valid certificate. It works fine on Andreoid 10 but not anymore on Android 12. RE: Android APP using HTTPS - jmir - 29.09.2022 (29.09.2022, 13:50)Daniel Wrote: It looks like google started to block https connections without valid certificate. It works fine on Andreoid 10 but not anymore on Android 12. But on the same device (phone) using chrome it works... RE: Android APP using HTTPS - Daniel - 29.09.2022 True, we need to look in to it. RE: Android APP using HTTPS - jmir - 07.10.2022 (29.09.2022, 14:41)Daniel Wrote: True, we need to look in to it. Have you found any solution? Thanks. RE: Android APP using HTTPS - Daniel - 07.10.2022 It is not something that will happen quickly. RE: Android APP using HTTPS - jmir - 30.10.2023 (07.10.2022, 07:23)Daniel Wrote: It is not something that will happen quickly. Hi, Have you solved this issue? Thanks. |
