Threads: 35
Hi All
We created app which will automatically generate SSL Certificate for selected domain. The domain will be linked to local LM IP and thanks to this locally you will be able to use HTTPS communication with valid certificate. This will work only locally. LM must have internet connection for this to work.
Here is video how this works:
Threads: 161
Will this app overwrites SSL certificate which is in System?
Done is better than perfect
Threads: 32
How can I connect with SSL certificat in Zerotier VPN? I can´t access to Logic Machine local IP with zerotier, only with Logic Machine Zerotier VPN IP (172.24...)
ZeroTier is already encrypted so there's no point in using SSL there.
Threads: 0
is it possible to get this app for W4K?
Thank you
Threads: 35
It will not work on W4k as it require connection to our cloud. SE has different not done by us.
Threads: 35
Go to app store and install.
Threads: 0
I have a problem with the SSL certificate app. When I’m filling out the activation key and pressing “Activate” the app is loading for a few seconds and then I get a popup with the following message: “Error: read status line failed timeout”. If I then refresh the website and press activate again, I get the following message “Error: domain is already active”. If I try to access the LM5 through the selected Domain name no SSL certificate is presented. Any clue on what could be wrong here?
Threads: 35
Which fw and what version of the app do you use?
Threads: 0
I’m currently running firmware version 20240426 with SSL certificate app version 20210422. I have also tried reinstalling SSL certificate app without it fixing the problem.
@admin, after I installed the updated app you linked the registration worked and it is now presenting SSL certificate on the selected domain.
