GET request - Printable Version +- LogicMachine Forum (https://forum.logicmachine.net) +-- Forum: LogicMachine eco-system (https://forum.logicmachine.net/forumdisplay.php?fid=1) +--- Forum: Scripting (https://forum.logicmachine.net/forumdisplay.php?fid=8) +--- Thread: GET request (/showthread.php?tid=4696) |
GET request - a455115 - 03.04.2023 Hello colleagues! Sorry if I'm repeating a topic, but I didn't find what I needed in the search engine. I need to submit GET request with Bearer authentication token and then get the values which are in JSON format. The values are times and dates that I need to store and compare until the time comes and executes a scene - what is the best practice for this? And how to send the request with token? RE: GET request - admin - 03.04.2023 Use this to get JSON data, change token and url as needed: Code: json = require('json')
ltn12 = require('ltn12')
http = require('socket.http')
token = 'ABCDEF'
url = 'https://httpbin.org/get'
resp = {}
res, code = http.request({
url = url,
method = 'GET',
headers = {
authorization = 'Bearer ' .. token,
sink = ltn12.sink.table(resp),
resp = table.concat(resp)
resp = json.pdecode(resp)
log(resp)You can store time/value pairs in storage and use a scheduled script that checks if any event should run once a minute. RE: GET request - a455115 - 03.04.2023 Works great! Thanks admin! How do I store the data in the storage? RE: GET request - admin - 03.04.2023 https://openrb.com/docs/lua.htm#storage.set RE: GET request - a455115 - 04.04.2023 (03.04.2023, 11:18)admin Wrote: https://openrb.com/docs/lua.htm#storage.set Thank you very much admin. As always everything works. Since I have the end keyword in the table and lua recognizes it as end - log(resp.value[1].end.dateTime), how do I change it to work? RE: GET request - admin - 04.04.2023 Use ['end'] RE: GET request - a455115 - 04.04.2023 (04.04.2023, 06:29)admin Wrote: Use ['end']Where am I wrong? log(resp.value[1].['end'].dateTime) Lua syntax error at line 26: '<name>' expected near '[' RE: GET request - admin - 04.04.2023 Dot is not needed when using square brackets: Code: log(resp.value[1]['end'].dateTime)RE: GET request - a455115 - 04.04.2023 (04.04.2023, 09:39)admin Wrote: Dot is not needed when using square brackets: i am very stupid.. Thanks again! |
