GET request
Hello colleagues!
Sorry if I'm repeating a topic, but I didn't find what I needed in the search engine.
I need to submit GET request with Bearer authentication token and then get the values which are in JSON format. The values are times and dates that I need to store and compare until the time comes and executes a scene - what is the best practice for this? And how to send the request with token?
Use this to get JSON data, change token and url as needed:
12345678910111213141516171819202122
json = require('json') ltn12 = require('ltn12') http = require('socket.http') token = 'ABCDEF' url = 'https://httpbin.org/get' resp = {} res, code = http.request({   url = url,   method = 'GET',   headers = {     authorization = 'Bearer ' .. token,   },   sink = ltn12.sink.table(resp), }) resp = table.concat(resp) resp = json.pdecode(resp) log(resp)
You can store time/value pairs in storage and use a scheduled script that checks if any event should run once a minute.
Works great! Thanks admin!
 How do I store the data in the storage?
https://openrb.com/docs/lua.htm#storage.set
(03.04.2023, 11:18)admin Wrote: https://openrb.com/docs/lua.htm#storage.set
Thank you very much admin. As always everything works.
Since I have the end keyword in the table and lua recognizes it as end - log(resp.value[1].end.dateTime), how do I change it to work?
Use ['end']
(04.04.2023, 06:29)admin Wrote: Use ['end']
Where am I wrong?
log(resp.value[1].['end'].dateTime)
Lua syntax error at line 26: '<name>' expected near '['
Dot is not needed when using square brackets:
log(resp.value[1]['end'].dateTime)
(04.04.2023, 09:39)admin Wrote: Dot is not needed when using square brackets:
i am very stupid..
Thanks again!
