LM5 can't send an email - Printable Version
+--- Thread: LM5 can't send an email (/showthread.php?tid=4714)
LM5 can't send an email - Fahd - 14.04.2023
I'm using this script in all of our projects to send a backup each month.
One of the LM5 can't send it anymore and  got this in the logs
* string: connection refused
* nil
* string: Send Mail
NB: LM5 is connected to the ethernet.
What could be the issue?
--***************************************************************-- --*** For FW spaceLYnk 1.2.1 and FW homeLYnk 1.5.1 or higher ****-- --***************************************************************-- --** Email backup as attachment created by Erwin van der Zwart **-- --***************************************************************-- --********************* Start of parameters *********************-- --***************************************************************-- --Gmail (smtp) username !IMPORTANT! user = 'xxxx' --Gmail (smtp) password !IMPORTANT! password = 'xxxx' --Sender for e-mail from = '<xxxx>' alias_from = 'From me' --Recipient for e-mail to = '<xxxx>' alias_to = 'To you' --Subject for e-mail subjectpart1 = 'Back-up file' subjectpart2 = 'xxx' --Message on bottom of email (will only be showed when client don't understand attachment) epilogue = 'End of message' --***********************************************************-- --******************** End of parameters ********************-- --***********************************************************-- --********** DON'T CHANGE ANYTHING UNDER THIS LINE **********-- --***********************************************************-- --Create table to include mail settings local settings = {     from = from,     rcpt = to,     user = user,     password = password,     server = 'smtp.office365.com',     port = 587,     secure = 'tlsv1_2',         starttls = true, } --Create attachment src = 'backup-' .. os.date('%Y.%m.%d') .. '.tar.gz' dst = '/home/ftp/' .. src -- prepare files for backup os.execute('sh /lib/genohm-scada/web/general/backup.sh') -- create cleanup archive os.execute('cd /lib/genohm-scada/storage && tar -c -z -f ' .. dst .. ' ./') --Create subject subject = subjectpart1 .. ": " .. src .. " " .. subjectpart2 --Load required modules to send email with attachment local smtp = require("socket.smtp") local mime = require("mime") local ltn12 = require("ltn12") --Create e-mail header settings.source = smtp.message{ headers = {           from = '' .. alias_from .. ' ' .. from .. '',           to = '' .. alias_to .. ' ' .. to .. '',           subject = subject }, --Load attachment inside body     body = { preamble = "", [1] = {        headers = {          ["content-type"] = 'application/x-7z-compressed',          ["content-disposition"] = 'attachment; filename="'..src..'"',          ["content-description"] = '.. src ..',          ["content-transfer-encoding"] = "BASE64",       },                      body = ltn12.source.chain(       ltn12.source.file(io.open(dst, "rb")),       ltn12.filter.chain(       mime.encode("base64"),       mime.wrap()         )       )     },       epilogue = epilogue   } } --Send the email r, e = smtp.send(settings) --Create alert when sending gives an error with error message if (e) then   log (e)   log (r)   alert("Could not send email: ", e, "\n") end log("Send Mail") --Delete created backup file from tmp folder inside HL os.execute('cd /lib/genohm-scada/storage && rm -rf user userlib.luas blockly.luas initscript.lua helpers.js genohm-scada.config filter*')
RE: LM5 can't send an email - Daniel - 14.04.2023
Check this
https://forum.logicmachine.net/showthread.php?tid=4076&pid=26361#pid26361
RE: LM5 can't send an email - Fahd - 14.04.2023
(14.04.2023, 09:19)Daniel Wrote: Check this
The same script works on another LM5, and im not using gmail
Is it the same gmial account?
(14.04.2023, 09:26)Daniel Wrote: Is it the same gmial account?
the same account yes
Then it is ether typo in internet settings or some security stuff in gmail.
(14.04.2023, 09:27)Daniel Wrote: Then it is ether typo in internet settings or some security stuff in gmail.
it's not gmail, and i don't thing a typo because i copied the same script and test it and it works
RE: LM5 can't send an email - admin - 14.04.2023
Try pinging SMTP server from LM.
(14.04.2023, 09:29)admin Wrote: Try pinging SMTP server from LM.
PING smtp.office365.com (132.245.230.0): 56 data bytes
64 bytes from 132.245.230.0: seq=0 ttl=107 time=35.128 ms
64 bytes from 132.245.230.0: seq=1 ttl=107 time=41.218 ms
64 bytes from 132.245.230.0: seq=2 ttl=107 time=34.290 ms
64 bytes from 132.245.230.0: seq=3 ttl=107 time=33.080 ms
--- smtp.office365.com ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 33.080/35.929/41.218 m
Is it the same firmware on working and not working LM?
(14.04.2023, 09:38)Daniel Wrote: Is it the same firmware on working and not working LM?
Yes
Try running this script. If you still get connection refused error then contact Microsoft and ask why your connection is blocked.
sock = require('socket').tcp() sock:settimeout(5) res, err = sock:connect('smtp.office365.com', 587) sock:close() log(res, err)
RE: LM5 can't send an email - Fahd - 28.04.2023
(14.04.2023, 11:37)admin Wrote: Try running this script. If you still get connection refused error then contact Microsoft and ask why your connection is blocked.
The problem is solved,  port 587 was blocked by the firewall
